dcollins wrote on Fri, 09 September 2005 02:15 |
bobkatz wrote on Thu, 08 September 2005 14:57 |
The physical master is sealed in a plastic bag with a "do not open except at factory" sticker.
No briefcase with a handcuff, like 007?
No, just protection from DC's XRay vision.
Quote: |
Quote: |
I go by the principle that if a copy of the master sounds good, then the master must be good!
Bzzzzzzzt!
Someone, if not you, must listen to the master before it goes out!
Simple as that.
I'm glad that you know you're right and I know I'm right. It's a very subtle distinction so watch the semantics fly:
The principle is that you have to make a copy at some time, so the time to do the audition is while you are cutting the copy. In the old days of PCM-1630 DMR with RAW heads you could listen to what was coming off of the read heads of the dub machine. What are you listening to then? The master or the copy? Does it matter?
In more detail:
Step one: During the mastering process there will be a 1X listen from start to finish. This will either be during a 1X cut of the physical master or to the file that will be transferred to the physical master.
Step one A: PQ code and cut the master if step one was to a capture file.
Step two: Test the master CDR for errors and load it back into an EDL onto hard disk using SADiE's import which copies the PQ codes from the master to a new EDL exactly. Test each of those Index marks, verify that the ISRC and CD text read correctly from that source.
Step three: Make a QC copy at 1X speed of the master from this EDL, while auditioning in headphones for noises, clicks, other problems. Since this is an EXACT copy of the master and if it is approved, then the master must be good. If there is a problem on the copy, the reverse is of course not necessarily true. If the client hears a problem on his copy we can go back to the copy image from the original master on our hard drive to listen to.
Step four: Pass the QC copy to the client for their approval. No one plays the master again until it reaches the plant.
Name one example of how there can be a problem or error in the master that will not appear on the copy? Give one example of how a 1X playback of the master for auditioning would be superior in any way to the above technique.
We've cut hundreds of masters in 3 years this way with no problems.
BK
