Ronny wrote on Sun, 11 September 2005 10:53 |
There can always be a defect in the media itself, Bob.
And that won't transfer to the clone? If there is an error in the source that produces an audible problem, that will be transferred to the copy.
The master disc has been error checked for media errors to be extremely low or it won't pass muster.
Each time a compact disc is played, slightly different correctable errors in different places on the disc occur because there is some "slop" to the design, a little spec of dust here or there, hopefully all of that is correctable. The ONLY time an audible error is generated is if there is an uncorrectable error. Each time you play any disc, its audible output will sound the same UNLESS there is an uncorrectable error, which will result in an interpolation that could be inaudible, or have a tic or pop.
Whether you listen to the original physical disc or whether I listen to a copy of that original disc, there is no guarantee that the next playback will be identical EXCEPT that we count on the fact that the error rates were measured low and that the system is robust. Can you be ABSOLUTELY certain that any particular moment of playback is not a "smoothed out" interpolation? Most uncorrectable errors remain inaudible because the interpolator produces a benign sonic result.
However, since the error correction mechanism on CD is extremely rugged, since uncorrectable errors are very rare on vetted media, and since we had already tested the medium for low errors, the chances of this happening on any play are slim.
But it could happen. So any time ANY of us listens to a disc, perhaps an uncorrectable error might creep in. If we really want to get serious, we should put idiot light error readouts on a CD player to accompany our listening QC just as we had with the 1630. And a timecode readout as to where on the disc that error occurred. But we don't do this, because the error correction mechanism on the CD is extremely robust; we count on that during our QC process.
My point is that if the uncorrectable error does happen, it will happen on the playback of the source disc OR during the dubbing to the new medium (hard disc). I count on this principle when I dub from the playback CD to my hard disc for the second generation copy which generates the QC listen while we cut the CDR QC copy in real time. There is no effective difference as far as I'm concerned.
And the sealed hard disc is a much more reliable mechanism, it doesn't even need a CRC check.
If we hear a problem, we go back to the source files to see if it's there. Same as you would if you heard a problem on your QC. Only we're one step closer than you and even more precise and quick... We're listening on a networked SADiE system in a SADiE project. All we have to do is mark the time code where the questionable noise occurred, WHILE we're making the QC copy. Then we open the source EDL and immediately listen to the source. IF there's a problem that we should have caught, it goes back to the mastering studio, where I denoise the click or tic or fix the problem, and then rerun that portion of the master through our processors, which then gets edited back into the capture file and a new master is cut with the correction.
10 years ago I heard an engineer rave how great a particular new CD blank "sounded" because it had the lowest error rates he had ever measured. Give me a break! This is suggestability at its height.
Years ago we discovered that as 16-bit PCM-F1 tapes aged, little tiny "tics" would start to become audible in soft passages. This was an indication of the beginning of uncorrectable errors. To make masters from these tapes we had to dub them several times as usually the tics appeared in different places so we could edit the good parts together. The re-edited copy became the new master. Today we would probably use a declicker to fix the tics.
Every archival organization storing digital media have to "renew" the media, typically every 5 to 10 years. Copies are made and the data is migrated to a new medium. The old medium is, I think destroyed. The entire world relies on this concept----that digital copies are as good as the originals, and from the point of view of error rate, a new digital copy is probably BETTER than an old original.
The only reasonable argument I've heard from you guys in this thread in favor of auditioning the original media is Brad's very reasonable adage "never turn your back on digital". Or "you never know what can happen". You're increasing the chances of error by making life more complicated.
But not necessarily; if we can cut the QC copy that the client is going to audition while we are QC'ing the master, then we are doing the client a service as well. Think about it. We get additional controls over the master, including having an exact clone of the master on our hard disc as a reference, which generates all the QC copies.
And based on my arguments in this thread, it should be clear to you that I feel that ANY error or problem that would occur in the playback of the master will show up on the QC copy. Hundreds and hundreds of approved masters later, I can attest that this is a fact. In the end, regardless of how you feel about my practice, it is true in both cases that only the ears of the QC person separate mastered success from
failure.
BK
