Author Topic: compressor purchase and use  (Read 2962 times)
Abbeyville Road
« on: November 08, 2008, 03:13:28 PM »
I have about $2000 to spend on a compressor. I record mostly acoustic instruments and sometimes vocals.
1) Looking for suggestions on a 2 channel compressor to multitask on vocals and instruments.
2) How much compressing do you normally do before the mastering stage?
3) Would I be able to use the same compressor suggested, to do mastering?
Thanks,
Jim Easton
Jim Easton
Abbeyville Road Studios
http://iacmusic.com/artist.aspx?id=104873
mcsnare
Re: compressor purchase and use
« Reply #1 on: November 08, 2008, 03:23:55 PM »
If you can add a little to your budget a Pendulum OCL-2 is exactly what you are looking for IMO.
Dave
MASSIVE Mastering
« Reply #2 on: November 09, 2008, 03:37:45 AM »
1) Agreed, I'd pick it up just a whisker if you can.  A whole bunch of used units would fall into the $2500-ish area.
2) As much as necessary (which is generally as little as possible).
3) Depends...?  It's a pretty vague quesiton...
John Scrip
Massive Mastering - Chicago (Schaumburg / Hoffman Est.), IL - USA
bluecouchstudios
« Reply #3 on: November 09, 2008, 09:39:35 PM »
The API 2500 is as close as you'll get.  You could probably find it new for around $2,300 or used for a little less.
PS - I should add that the Waves version of the API 2500 is pretty darn good.  It's what I'm using until I can afford a Crane Song STC-8.
lance
Sean Magee
« Reply #4 on: November 12, 2008, 09:24:59 AM »
MASSIVE Mastering wrote on Sun, 09 November 2008 08:37
what he said....but for no.2   be very very very careful with compression on the mix. i'd use a ratio of 1.1:1 maybe 1.2:1 if i was feeling brave.  basicly....do what you think...then back it off.
my favourite compressor at the moment is the junger accent 2. digital i know,...but very very nice, and no mucking about with too many parameters...failing that i use tape compression (preferred)
Page created in 0.098 seconds with 19 queries.
