Author Topic: G4=power?  (Read 6197 times)
Iain Graham
Re: G4=power?
« Reply #15 on: December 14, 2007, 09:56:25 AM »
Finding it however, is not so easy....
And that i exactly what I meant.
Iain Graham
www . iain - graham . com
http://www.myspace.com/iain_graham
www . soundart . com
mattrussell
Re: G4=power?
« Reply #16 on: December 14, 2007, 12:24:40 PM »
i have a g4 dual 1.25 i'm about to unload.  my plugs are ALL RTAS.  PT 7.x runs terribly on it.  can't get nearly the plug counts i was getting on 6.4 with panther.  tiger is a HOG and the 30% gain in RTAS "power" that digi added with ver 7 doesn't help at all.  some sessions i ran with little trouble won't play AT ALL in ver 7.  if you're running mostly TDM plugs (esp. the verbs, MB Comps, linear phase EQ's), you'll be fine.
on another note, the machines themselves are VERY noisy compared to a G5. i'm using a dual 2.3PPC machine right now and it is whisper quiet.  my G4 is ten times louder than this box - without a doubt.
buying a quad-core Intel Mac, 2.66 this weekend.  can't wait.
matt russell
producer/engineer
boston, ma
http://www.gainstructure.com
neilio
Re: G4=power?
« Reply #17 on: December 16, 2007, 04:36:11 PM »
well fully blown mix+ systems used to run off powermac g4 466's...
which is the whole point of the tdm architecture...the host cpu really is merely an interface and a controller not processing anything unless you use rtas plugs....
so a dual 1.25 g4 will be a very viable host cpu for a mix system, the thing to watch out for is what os vs. what version of quicktime vs. what version of pro tools you are using...there is very specific window of compatibility for these older systems...but once that is sussed out it will be a rock solid system...
and there is the option to use something like an ad8000 instead of the 888's, albeit at 48k/24bit max...
tom eaton
Re: G4=power?
« Reply #18 on: December 16, 2007, 06:28:20 PM »
My G5 dual 2.7 is WAY louder than my G4 dual 1.42.  I couldn't believe it when I first ran the thing.  I thought the G5 was supposed to be a quieter machine.  Mine is louder than any G4 I've owned (733, dual 1.0, or the dual 1.42).
I wonder how much variance there is between machines.
t
Jay Kadis
Re: G4=power?
« Reply #19 on: December 18, 2007, 11:29:05 AM »
tom eaton wrote on Sun, 16 December 2007 15:28
t
I found a lot of difference in fan noise between OS versions on my dual 1.8GHz G5.  Upgrading to 10.3.9 (or maybe it was 10.3.8 ) reduced the fan volume considerably.  A friend with a single 1.8GHz G5 had some defective fans that made huge noise and eventually were replaced under warranty.
j.hall
Re: G4=power?
« Reply #20 on: December 18, 2007, 11:34:45 PM »
Berolzheimer wrote on Thu, 13 December 2007 18:08
 I hate to say it but I think a lot of the info you're looking for is available on the Digidesign website.
100% completely true.  though their search engine is TERRIBLE.......almost as bad as their useful information on mix + systems.  neither of which i blame them for.
bblackwood
Re: G4=power?
« Reply #21 on: December 22, 2007, 08:30:05 PM »
From what I hear, you should just get a G5 - it will be worth the (financial) wait, if there is any.
Of course, I'm just a lowly mastering guy who has zero knowledge of ProTools, so basically ignore everything I say.
Brad Blackwood
euphonic masters
tom eaton
Re: G4=power?
« Reply #22 on: December 23, 2007, 08:33:11 AM »
Jay Kadis wrote on Tue, 18 December 2007 11:29
Interesting... in my situation it was the same OS on both machines, 10.4.8.  Maybe my machine runs hot?  Temperature monitor shows no particular strangeness.
I don't know hot hot it SHOULD be running, though...
-tom
Page created in 0.105 seconds with 20 queries.
