I have a rack of 11 API 312 pres. However, one of these pres has gone bad. I love the sound of these pre amps and so would rather repair the one 312 that is bad instead of replacing it with something else.
Does anybody know where I can get some replacement 2520 amps? I am looking for the older ones, not the currently manufactured ones.
I have heard that API will repair API modules, but that they will only replace 2520s with their newer 2520s. However, I think this only applies to their currently manufactured units and not the older 312 cards. Is this true? If so, that might be an option if I cannot find any original 2520s but I prefer an original 2520. (which brings up the question of what is the sonic difference between the newer 2520s and the older original 2520s).
I have an API 554 (the parametric EQ) but it has two 990 amps instead of the 2520s. I also have several of the original 550A EQ with original 2520 amps. The EQ with 990s sounds so different from the EQ with 2520s that I very seldom use the 990-equiped 554. For this reason, I really want to repair this 312 pre amp with an original 2520.
So, any leads on where I can find some 2520 amps would be appreciated. BTW, I have already checked with Bret Averill and they do not have any original 2520 anymore.
Thanks,
-Andres
