Author Topic: What Does DEHORNED Mean?  (Read 11635 times)
bigaudioblowhard
« on: April 05, 2007, 04:08:16 PM »
Okay, bring on the jokes.
But seriously folks, just recieved some METAL MOTHERS that had big red
stamped lettering that reads
DEHORNED
What is this?
bab
Darth Fader
Re: What Does DEHORNED Mean?
« Reply #1 on: April 05, 2007, 07:13:35 PM »
Are you sure that's just not the name of the band and the album??
Husky
bblackwood
« Reply #2 on: April 05, 2007, 07:39:52 PM »
From an interview with Stan Ricker:
Quote:
Q: What's your opinion of the dehorning of masters?
A: Well, I don't know of anybody who does that anymore.
It seems to have been fairly popular in the sixties or seventies or whenever.
A cutter stylus cuts and it also plows.
With a snow plow you go down the road and you pile up all this humongous crap along the curbs and sidewalks.
Well, you hope you don't get much of that when you cut.
Cutter styluses are manufactured much better nowadays than, shall we say, thirty years ago.
The burnishing facets weren't so accurate then.
Sometimes you got a nice cut in the groove but then sometimes you didn?t, and there might be a bunch of stuff stacked up at the edge of the groove.
That stuff was rough-textured and made separation of the lacquer master from the first metal plating very difficult, because the stuff that's thrown off, when viewed under a microscope, looks like a string of cinders.
It's porous, like a sponge, you see.
So when you're electroplating that stuff, well, the metal molecules get inside and you can imagine metallic nickel getting inside a sponge and then how do you peel a sponge off that electroplating?
You're left with little bits of stuff stuck to the metal (NOISY!).
So the idea was to knock off those.
It affects the sound.
I don't know anybody who does dehorning anymore.
At least I don't know anybody that's involved in high quality work who does it, mostly because there?s no need for it with today?s better styli."
Brad Blackwood
euphonic masters
TotalSonic
« Reply #3 on: April 05, 2007, 07:44:56 PM »
bigaudioblowhard wrote on Thu, 05 April 2007 16:08
DEHORNED
What is this?
bab
When you pull off a nickel father off of the original silvered lacquer master it sometimes can have the impression of the "horns" - the material pushed to the sides during the cutting of the lacquers - which are tiny bits of material on the surface (on the uncut land that goes along the top of the grooves) that extend out like horns when you look at them under the microscope.  These are often removed  in a process called "dehorning" in order to create a stamper that won't press these defects into the vinyl record itself.
As Stan Ricker noted dehorning came into disfavor with many plating facilities as cutting and plating techniques improved and minimized the occurance of the problem - and also because the process of dehorning can sometimes lead to decreased definition of the program material if it is not done carefully.
fwiw - at Europadisk we wouldn't dehorn the stampers that we pulled off of the Direct Metal Masters.
Best regards,
Steve Berson
minister
« Reply #4 on: April 05, 2007, 09:15:49 PM »
bigaudioblowhard wrote on Thu, 05 April 2007 15:08
Un-Cuckolded.
tom hambleton C.A.S.
minister of fancy noises
ministry of fancy noises
IMDb
Gold
« Reply #5 on: April 05, 2007, 09:58:45 PM »
Only necessary for Jewish fathers.
Paul Gold
www.saltmastering.com
On the silk road, looking for uranium.
MASSIVE Mastering
« Reply #6 on: April 05, 2007, 10:21:38 PM »
It's what happened to Satan at the end of that Tenacious D movie.
John Scrip
Massive Mastering - Chicago (Schaumburg / Hoffman Est.), IL - USA
bigaudioblowhard
« Reply #7 on: April 06, 2007, 06:34:34 PM »
Thanks everyone, great to know, good to go.
bab
bigaudioblowhard
« Reply #8 on: April 08, 2007, 03:49:29 PM »
TotalSonic wrote on Thu, 05 April 2007 17:44
Best regards,
Steve Berson
Steve, I'm assuming one DEHORNED the lacquer BEFORE  the first plating, no?
As I understand it, the horns would be negative on the FATHER, or like little holes in the uncut land between grooves.
bab
TotalSonic
« Reply #9 on: April 08, 2007, 06:26:25 PM »
bigaudioblowhard wrote on Sun, 08 April 2007 15:49
Best regards,
Steve Berson
I'm not positive about this, as I was never hands on with plating lacquers, but I believe it's also possible to dehorn the nickel mothers.
lacquer master (negative) > nickel father (positive) > nickel mother (negative) > nickel stamper (positive) > vinyl record (negative)
Maybe someone who has more experience in this regard can chime in here and further clarify.
exactly.
My second post is confusing as I should have stated that fwiw Europadisk never dehorned the mothers (not stampers as originally posted) even when we received nickel mothers made off of lacquer masters.
Best regards,
Steve Berson
Gold
« Reply #10 on: April 08, 2007, 08:25:38 PM »
I'm pretty sure you wouldn't mess with the lacquer. It's too soft and prone to damage. You probably dehorn each mother pulled off the father. I can ask, to be sure I'm not spouting BS.
I think that to dehorn you use an abrasive metal polish.  I'll check that too.
Paul Gold
TotalSonic
« Reply #11 on: April 09, 2007, 01:27:42 PM »
I'm not positive but I think it might be possible to dehorn the lacquer after it has been silvered.  I'm pretty sure that it would most often be done to the mothers though.  Too bad someone like Desmond from Mastercraft doesn't post here as he could clear this up in a second.
Best regards,
Steve Berson
ak
« Reply #12 on: April 15, 2007, 04:09:33 PM »
Hi,
it is necessary to "dehorn" mothers when the master was
a lacquer disk. Thats what all good plants do.
but it has to be done right. otherwise a looot problems can occur. (Don´t want to write a book now..)
This information on your mothers is important that it will not done twice.
afaik all good german pressing plants dehorn (in german : polieren = polish or schwabbeln) their mothers to get
proper quality pressed.
Good ones listen to the entire mother if it´s ok (1st audible quality check). One plant i know is able to cut out crackles which caused by dust when it was on the lacquer while silvering.
This can happen when dust sticks to the disk and could not be removed completely after washing the lacquers.
This is mostly interesting for laquers which get shipped in
dusty boxes or for audiophile stuff.
They can also repair overcuts sometimes, then they are nearly unhearable.
When i make cuts for overseas pressingplants to make sure the
quality of the record will be good i often sending them mothers from my favourite plant (dehorned, and tested) so the other plant
just have to do the stampers and can press. Makes more sense then to send out lacquers on a long journey, especcially not if its summer. And if you know that a plant has a bad Galvanik quality.
A lot of myths are going around if a mother is polished (dehorned) to long or to hard the highs can get lost.
Anyone made some experiments ?
greetings
Andreas
Schnittstelle
Mastering & Vinylschnitt
Frankfurt - Germany
Gold
« Reply #13 on: April 15, 2007, 11:11:25 PM »
ak wrote on Sun, 15 April 2007 16:09
but it has to be done right. otherwise a looot problems can occur. (Don?t want to write a book now..)
The place I use most often doesn't  dehorn on a regular basis. He will do it on request if the side is noisy. He thinks that 'if it ain't broke don't fix it.' I've cut many very quiet sides without incident.
Are you talking about the 'zzzpht' sound you can get when grooves kiss? If so that's very nice.
I prefer to ship metal parts too.
No. It seems plausible but if the test pressings sound good, why argue?
Paul Gold
Bob Olhsson
« Reply #14 on: April 16, 2007, 12:55:55 AM »
My understanding is that dehorning became a lot less common after the introduction of modern heated cutting styli in the 1960s.
Page created in 0.245 seconds with 21 queries.
