So, I'm trying to locate The Wind Noise on my friends Twin Reverb. I isolate the problem at V4, a 12ax7, which is the reverb recovery tube. Figuring it's a failing component or solder joint, I go through the steps to rid the amp of the noise. After finding that no component in the input circuit of this tube is seriously out of spec, failing or otherwise not working correctly, the noise is still there. So on a whim I replaced the wire connecting the grid to the load resistors etc, and the noise was gone. To make sure I wasn't missing something, I put the old wire back, and sure enough the noise was back. When I tapped on the wire, it was like tapping on a microphonic tube.
So, am I missing something? I'm young and inexperienced, so be kind if this is common, but I've never seen this before. What would cause a wire to behave like this?
