Loco wrote on Thu, 28 July 2005 11:50 |
Ronny wrote on Wed, 27 July 2005 22:04 | the difference between a 12x and a 52x disk is that the 52x disk can be written up to 52 times real time speed before vibration becomes a factor. A basic explanation is that the 52x disks are more balanced
Hell no! I'm absolutely sure that's not the case. The speed is related to the reflectivity of the surface as well as it's reaction speed to the laser at the time of burning.
Before you confirm yourself to being absolutely sure, let me remind you that no matter what speed a disk is recorded at, they will all play back at 1x and reflectivity is not an issue on the burn, only on the playback. Understand? Also, the higher speed disks have a thinner dye layer so that the data can be burned faster and it doesn't matter what speed the disk is "rated" for, it can only be burned at the max speed that the burner supports, for example I have 52x Plextors and 12x Plextors, stick a 52x Taiyo in the 12x and it will only burn tops of 12 times. In fact the 52x burners seldom burn at more than 48x. Recording speeds are never fixed, if you set it to 4x, than it's going to operate between 3 and 5x and 4x will be the average.
5. What does the "X" stand for?
The "X" of discs is a measure of how fast they can be recorded in a drive rated to be capable of that speed. A 32X disc can be recorded at 32 times normal speed (normal is the playback speed of a music CD). A 32X disc will record in a drive rated at 32X, but only at 16X speed in a drive rated only for 16X maximum.
(Back To Top)
6. Why won't my 48X recorder record at 48X?
There could be several reasons for this.
1) The CD-R disc may not be 48x compatible so the drive will bump down its recording speed.
2) System performance may be poor causing slow data transfer and thus unreliable recording at 48x.
3) Authoring software may need to be updated.
(Back To Top)
7. Are 52X discs better than 16X discs?
Faster discs have thinner dyes that react faster to the laser light and the greater laser power used.
There is no quality difference in this regard, although discs rated at the highest speeds have to have excellent balance, concentricity, and uniformity so that they do not cause problems for high speed drives. Reprinted from Nashua cd manufacturers guideline.
