PookyNMR wrote on Fri, 10 December 2004 16:13 |
Interesting that Bob mentions using digital wire for audio cables. Is there a suggested capacitance for audio cables (with runs of 50 ft or less)?
Nathan
A couple of comments about capacitance:
First, capacitance may be a factor at lower frequency (such as audio). At higher frequencies, unless the cable is reasonably consistent and is terminated in the proper characteristic impedance, one deal with capacitance and inductance issues. For now I will stay with audio signals (low frequencies). Clearly capacitance depends on cable type (including the various dimensions and materials) and on cable length. The key capacitance specification is typically given in pf (pico Farad) per foot.
In order to figure out the impact of capacitance on signal flatness response, one should know the source and load impedances.
Say you are driving a cable (capacitance) C. Your source is 75 Ohm resistive, and the load is high impedance. This is pretty typical to audio. Say you wish to have about 1% loss at 20KHz (less than .1dB). It would take 16200pF of capacitance to do the “specified .1dB damage”. Chances are that your cable capacitance is somewhere between 10 and 100pF per foot. Assuming 30pf/ft, it would take 162 feet for -.1dB at 20KHz.
But say you have a 5KOhm source resistance. You will now lose .1dB at 20KHz with 2.5 feet cable. In fact 54 feet will bring your 20KHz down by 3dB.
There are cases such as a high impedance transducer, a passive attenuator box and more where the cable capacitance matters in terms of amplitude response. But in most cases it is not a flatness response issue. So what is it about?
So far I only touched on the interaction of load and source with the cable capacitance.
The more important factor regarding cable capacitance is the interaction with the analog driver.
Sure it would be great to have zero capacitance, but as always, there are tradeoffs. For example, reducing the inner conductor diameter will decrease capacitance, yet you would not want to overdo it. Thicker insulation of the right material will decrease capacitance, but often as a tradeoff to another important factor.
Cable length is the one factor that is always there. The shorter, the better. In other words, if you need 10 feet, don’t have a 20 feet cable (and don’t role the access into loops, which will act like a pickup antenna).
Are you using balanced or unbalanced mode?
Regards
Dan Lavry
