Hey Typek and troubleshooters-
Did you ever figure out your transport problem?
My scenario might be a little bit different since I've got a Tascam TSR-8, but this thread seems like the closest to what I've found through my forums search so far.
My capstan turns, my reel motors work, but all of my solenoids (brake, capstan, lifter) suddenly quit working. As a result, I've only got ffwd. The lifters don't lift, play and rewind act like they want to go but merely rock a tiny bit.
I took the front plate off and checked the mechanics and everything seems to be in order. Upon further study I'm guessing that it isn't the solenoids themselves, since the likelihood of 3 going bad at the same time is nil.
There's a joint PCB that takes power from the power supply B PCB and feeds it to the solenoids. So, I'll attempt a fuse check, but that only localizes the true problem.
I'll see if I can get far enough inside the machine to check the solder at the heatsink-mounted voltage regulators. Provided mine has those.
Any other suggestions?
Thanks,
Mark Wolberg
