Author Topic: Big rank peak at 128 hz  (Read 3326 times)
jwhynot
« on: April 29, 2007, 10:24:33 PM »
Hey guys -
My workspace is in a living room, rented house, you know the drill.
I have some decent treatments in the room, and I'm planning to pack some of Ethan's traps in there too - but I wonder about trying to tamp down this ringing loud peak at 128 first.  It's most apparent in my chair unfortunately.
What's a good solution?  Resonator of some sort?
Open to suggestions here
Thanks
JW
one of both the most and least successful producers of ALL TIME!
Tom C
Re: Big rank peak at 128 hz
« Reply #1 on: April 30, 2007, 12:02:45 PM »
jwhynot wrote on Mon, 30 April 2007 04:24
Hey guys -
Thanks
JW
I don't know your room's dimensions, but 128 Hz seems to be the
typical ringing between floor and ceiling.
I'd put an appropriate hanging broadband (bass-) absorber on the
ceiling above your chair (4" and more) and (depending of the
room's height) play around with the absorber/ceiling distance
until it sounds (and probably measures) good.
Tom
Tom
.signature failure
franman
« Reply #2 on: May 06, 2007, 10:29:00 PM »
Good observation Tom.. and good advice as well.
fmdesign.com
griffinaudiousa.com
jwhynot
« Reply #3 on: May 07, 2007, 03:40:21 AM »
Thanks guys, that's what I reckoned.
I have an absorber right above my head but I'm pretty sure it's not efficient (or massive) enough.
Since it's just the one frequency, does it make sense to use a resonant device of some sort?  Slot absorber?  Helmholtz?
Or should I just call Ethan and get one of his traps up there?
JW
matucha
« Reply #4 on: May 07, 2007, 05:10:15 AM »
I'd first fill all the corners (possible) with rockwool (or 703) before building any tuned device.
Tom C
« Reply #5 on: May 07, 2007, 06:39:45 AM »
jwhynot wrote on Mon, 07 May 2007 09:40
JW
I can only speak for my room, but to have a measurable effect in
my room a tuned absorber would have had about the same size as a
broadband absorber, so I went broadband.
Tom
Tom
.signature failure
Ethan Winer
« Reply #6 on: May 08, 2007, 01:54:37 PM »
matucha wrote on Mon, 07 May 2007 05:10
Just to be clear, the traps my company sells are broadband, not tuned.
--Ethan
maccool
« Reply #7 on: May 10, 2007, 05:31:48 PM »
Good to see you back John, I hope things are going well for you since the fire.
I have the same rank peak which stuffs my acoustic guitar recordings, and I'm going to fix it with broadband absorption on the ceiling as Tom suggests.
"Live sound will always be different."  Paul Frindle
jwhynot
« Reply #8 on: May 11, 2007, 12:57:07 AM »
My vertical corners are mostly killed already - using a variety of methods.
I think it's a matter of some realtraps products.
Ethan - thanks for responding - I know your products are broadband.
Will get in touch when the smoke clears on the current work - in the next 3-4 weeks.
Thanks all
JW
PS Thanks maccool - yes things are just great 16 months after the fire.
Page created in 0.099 seconds with 22 queries.
