Jim Frazier wrote on Wed, 02 August 2006 15:46 |
Hi,
I own Lavry 4496's, and my question is regarding the usage of the sample rate switch on the front panel of the M-Sync module.
Like many of us, I'm working on a handful of projects at the same time. Most I start and finish at 44.1. But I'm doing some over dub work on a 48k project. I use Logic, BTW.
Normally, when I know I'm going to work at the higher sample rates, I quit Logic, change the setting on the Lavry's from 44.1 to 48, and then relaunch Logic. No issues there.
Yesterday, I was working on a 44.1 project, and without thinking, I moved on to the 48k project. I didn't relaunch Logic, or set the Lavry's to 48k.
I did a bunch of editing, and even recorded some guitar overdubs in this 48k project. All the while, the Lavry's remained set at 44.1.
About 2 hours into it, I realized I hadn't switched anything. I knew that the tracks were playing at the right speed, which made me wonder why the switch is there, because usually, if I switch between sessions with different sample rates, the one I switch to plays slow (or fast) as it is trying to play a 48K file with the Lavry's set to 44.1 (or visa versa).
What's even weirder, is that the guitar tracks I recorded, recorded at 48k, even though the M-Sync was set to 44.1
Obviously, the way I thought this worked is not necessarily true. Can someone enlighten me as to why the session played and recorded at 48k (which is what I wanted it to do), yet the Lavry's remained set at 44.1?
Thanks for your time...
Hi,
Here is the way the Msync works:
1. When the right most switch is set to INTERNAL:
a. The lock light will be off (there is nothing to lock to).
b. The WIDE/NARROW switch does nothing (there is nothing to lock to).
c. The 2 left switches set the sample frequency. The choice (44.1, 48, 88.2 or 96KHz) is indicated by one of the lamps.
2. When the right most switch is set to WC or AES (external sync).
First, setting the WIDE/NARROW to NARROW
a. In external sync mode, the idea is to make the lock lamp go on.
b. The unit expects a sync signal into the rear BNC connector. that signal should be WC (word clock) when the switch is at WC, or it should be an AES signal when the switch is at AES position.
b. You now need to set the 2 left most switches to the correct sample rate. You will know you are there when the lock lamp is on.
Second, when setting the WIDE/NARROW to WIDE:
a. This is similar to narrow, but given that the unit can accommodate a wide sample rate range, both the 44.1 and 48KHz are lit simultaneously (or 88.2 and 96KHz simultaneously).
So the only way I can explain your case is:
The unit was set to WIDE, and it followed what you fed it.
I simply can not see any way the unit can be in internal or external narrow mode, where the unit generates a 48KHz clock while indicating 44.1KHz, or visa versa.
The above is for AD. The DA will follow what you fed it, and will indicate the frequency it is receiving at the time.
Regards
Dan Lavry
