Many thanks for replay and clarifications Dan.
Quote: |
I do not know why you have such higher level up to 200Hz or so.
The power comes first on my mind. I'm using power straight from the outlet (220 here), without any voltage regulator (coming soon). The house is well grounded, but still power can be impure in many ways. Besides I expected some peak around 60 Hz. Again, EVERYTHING in the studio/house, except ADDA converter and PC, was unplugged from mains and wall sockets.
Quote: |
(and frankly I am not sure what your peak meter does – is it the peak value of an FFT? Peak of dynamic range???)
It's standard peak meter, measuring highest peak in dB (Sound Forge) not the VU(ppm).
In my case the most problematic area lies in 200 Hz and below. FFT graph is per given frequency band. Clear enough. Now there is another problem. I did some more FFT using the same file, but now with a bin per Hz (S. Forge allows only few fixed FFT sizes, so I set frequency range to match the number of bins).
First graph shows FFT size 512 on 0-512 Hz range and second FFT size 1024 / 0-1024 Hz range. I expected the same values on both graphs per given frequency, but it’s visible that, for example at 200 Hz, the highest value of noise is around -126 dB (FFT 512 graph) and on FFT 1024 graph the value is around -142 dB.
From where comes that difference if the FFT size/Hz proportion is 1:1?
Small step further, to stuck me more. Next two graphs: FFT size 8192 / 8192 Hz range and FFT size 16384 / 16384 Hz range.
Now, my whole problematic phantom area moved from 200 Hz to under 16 Hz and at last under 10 Hz.
Quote: |
It simply too difficult to say much without a lot of details.
I wish I could give you more spec and data but all I have found is:
Sample rates: 44.1 - 48k, 88.2 - 96k, 176.4 - 192k (+/-10%);
Frequency response: 10 - 20k (+/- 0.2 dB) at 44.1k
Analog max levels: adjustable between +2 dBu and +26 dBu
Dynamic range: 114 dB A weighted (AD + DA)
THD+N: -105 dB (AD), -103 dB (DA)
There are other things about number of ins/outs and similar but I suppose that’s irrelevant for the problem.
Best regards
