Quote: |
BTW, about the degradation and nulling. The files will null, in fact a 24 bit file dithered and quantized to 16 bit will retain all information above -93dB and will null with the file before quantization to the dithered noise floor of the final bit depth.
RoMo...(or Bob or anyone)...
I tried this test; & the results weren't as I expected.
I had been listening to hype suggesting that subsequent DAW versions sported audio engines that were nothing short of phenomenal (in terms of advancement)...
so I had created a project in SONAR2 of 9 tracks w/ 6 UAD-1 plug-ins (w/ 2 tracks panned hard left & right...since the discussion had centered on the possibility of newer software versions sounding different due to panning laws); & bounced the tracks to a stereo .wav, which I opened in the same project in SONAR4...
& it nulled perfectly...as it also did the other way around (S4 > S2)...
...[telling me that these newer versions may be re-written to provide greater node depth, fatten the code, or streamline the linkage within the architecture...but they can't change the fundamental structure of what they draw from the converters & in turn send to the hard disc & back again. They can't make PCM digital audio
sound any better, except in the way they handle plug-ins.]
But...in the process I thought I'd try your test.
I bounced the 16-Bit tracks to a 24-Bit file; & opened it up in WaveLab...where I first dithered it back down to 16-Bit utilizing Apogee UV22HR; & then just saved it as a 16-Bit file, which simply truncates the file.
I imported them both back into the original (16-Bit) project; & they both nulled.
So I thought...I hear nothing in the monitors...but is it a perfect null? I put the headphones on, cranked the volume all the way up; & listened.
The
dithered file was a perfect null...dead silence.
But in the truncated file, I could hear white noise & a faint piano !!!
So I had to come back to the brains at PSW & ask:
shouldn't it be the other way around ?*?*? It's dither that modulates the LSB & adds noise, right? I'm certain the files were labeled correctly 'cause I bounced & processed again with the same results.
Is that weird, or does truncation change the very bottom of the bit scale in an audible way...but then...dithering
doesn't?
mark4man
