Pages: 1 [2] 3 4 5   Go Down
Author Topic: Euphonic Analog Transfer Console (ATC-1)  (Read 41841 times)
jason goz
Re: Euphonic Analog Transfer Console (ATC-1)
« Reply #15 on: August 23, 2005, 10:15:37 am »
Thanks
Another question...
Why have you not used shielded wire?
Jason
bblackwood
« Reply #16 on: August 23, 2005, 10:16:52 am »
Jason Goz wrote on Tue, 23 August 2005 09:15
The entire chassis is shielded...
Brad Blackwood
euphonic masters
Greg Reierson
« Reply #17 on: August 23, 2005, 12:10:29 pm »
ammitsboel wrote on Tue, 23 August 2005 08:48
Relays don't sound as good as switches.
Mehcanical relays are switches.
My experience has been that a good gold contact switch and a good relay (Aromat, Magnecraft) sound exactly the same. Each offer functional advantages, but neither seem to impact the sound in any significant way.
What's your evidence that switches sound better than good relays? I'm really interested since I use relays often.
GR
jason goz
« Reply #18 on: August 23, 2005, 12:54:18 pm »
Brad
Quote:
The Shallcos were chosen as they have a large surface area and the action of the wiper across the surface keeps the contact surface clean. That and they are mil-spec and will be working fine long after I'm dead (reliability).
I like your style...where can i get those shallcos switches from.
OldSonic
« Reply #19 on: August 23, 2005, 01:31:34 pm »
ammitsboel wrote on Tue, 23 August 2005 17:48
Jason Goz wrote on Tue, 23 August 2005 13:27
1,Why no relays?
  Relays are just switches. Why do you think they are not so good?
Andrey Subbotin
JGreenslade
« Reply #20 on: August 23, 2005, 01:53:37 pm »
ammitsboel wrote on Tue, 23 August 2005 14:48
1,Why no relays?
One million dollars awaits you Henrik.
If you can hear the difference between a decent inert-gas filled relay and a switched attenuator you're wasted in the music industry, honestly - if I had a talent like that I'd be off to enroll in the Intelligence Services. The cold war may be over, but I'm sure they'll make an exception for someone with an ability like that.
Aren't you in danger of giving away trade-secrets showing people what's in your box Brad? Surely the business angle would be to seal the case and suggest something magical was going on under the hood :-) Clean work btw!
Justin
Audio is a vocational affliction
"there is no "homeopathic" effect in bits and bytes." - HansP
zetterstroem
« Reply #21 on: August 23, 2005, 06:20:23 pm »
justin.... with the talent you have they have an open position as chairman here... Very Happy
http://www.alaska.net/~clund/e_djublonskopf/FlatHome.htm
Noting the music industry's complaints that illegal downloading means people are getting their music for free, he said, "Well, why not? It ain't worth nothing anyway." (b.dylan)
ammitsboel
« Reply #22 on: August 24, 2005, 10:33:48 am »
Greg Reierson wrote on Tue, 23 August 2005 17:10
My experiences has just been lesser with relays compared to switches.
I think if you really have to be anal about it and make it as good as possible then I would use switches instead of relays.
I haven't studied why exactly this is thoug. Maybe the material... maybe because they are... dare I say it... MAGNETIC!!!
Henrik
"The male brain is designed for ecstasy" -Dr. Harvey "Gizmo" Rosenberg
Ronny
« Reply #23 on: August 24, 2005, 12:00:31 pm »
ammitsboel wrote on Wed, 24 August 2005 10:33
Henrik
Maybe because our ears play tricks on us when we evaluate solo and not in the blind.
bblackwood
« Reply #24 on: August 24, 2005, 04:14:44 pm »
Jason Goz wrote on Tue, 23 August 2005 11:54
http://www.shallco.com/
Brad Blackwood
euphonic masters
ammitsboel
« Reply #25 on: August 25, 2005, 08:42:41 am »
Ronny wrote on Wed, 24 August 2005 17:00
I think if you are not tired, hungry, stoned, depressed or having hangovers then you should be able to catch these differences with no troubles.
Best Regards
Henrik
jlarcombe
« Reply #26 on: August 25, 2005, 11:34:58 am »
ammitsboel wrote on Thu, 25 August 2005 13:42
The difference between relays and switches?
Are you joking?
Ronny
« Reply #27 on: August 25, 2005, 12:11:16 pm »
jlarcombe wrote on Thu, 25 August 2005 11:34
Are you joking?
This reminds of a discussion I heard once, where they were arguing about the differences between corvettes and stingrays.
Viitalahde
« Reply #28 on: August 26, 2005, 01:05:45 am »
ammitsboel wrote on Wed, 24 August 2005 15:33
MAGNETIC!!!
I asked you this in some previous topic months ago, but you didn't answer.
If you place a horseshoe magnet next your speaker cables, do you hear a difference?
A relay's coil is in a magnetic state in one position only. It's up to the designer whether that's in IN or OUT state, in the case of a bypass switch for example. Even then, designers tend to use DC operated relays, which means you don't have a small 50hz magnetic field next to your signal.
Jaakko Viitalähde
http://www.virtalahde.com
jackthebear
« Reply #29 on: August 26, 2005, 01:34:44 am »
Ronny wrote on Fri, 26 August 2005 02:11
Are you joking?
Sheesh.....EVERYONE knows the corvette is a marine creature
Very Happy
Tony "Jack the Bear" Mantz
Glorified Tape Copy Boy and
Audio Janitor
Deluxe Mastering
Melbourne, Australia
deluxemastering.com.au
+61 419234100
Facebook | twitter | MySpace
Pages: 1 [2] 3 4 5   Go Up
