Author Topic: Files question.  (Read 1417 times)
Blake
Files question.
« on: August 18, 2005, 08:55:19 pm »
So I tracked a band in Protools using SDII files.  Now the band needs the files as 24 bit WAVs.  How do I do that?  Can't I just make a new session in WAV format and just import?  Doesn't seem too hard, I've just never had to do it. Thanks for any advice.
archtop
Re: Files question.
« Reply #1 on: August 19, 2005, 08:58:52 am »
you could also triple click the timeline to select all used regions in the sessions
then in the menu for the regions bin select -EXPORT SELECTED AS FILES--
there is a spot to select wav's as the file type
Richard Williams
j.hall
Re: Files question.
« Reply #2 on: August 19, 2005, 08:59:02 am »
that will work if you dont' have any punches or things you need to stay time aligned.
the other way would be to bounce each file mono and convert to wav (this takes forever)
maybe "import to track" will do the conversion, that would be my first attempt. it's under the file pull down menu.
originalrecorderman
Re: Files question.
« Reply #3 on: August 19, 2005, 11:39:33 am »
save session copy as....
you have the abillity to save/convert at diff bit rates and depths and formats.
John Ivan
Re: Files question.
« Reply #4 on: August 19, 2005, 12:09:00 pm »
I don't know much about protools these days. I have a question also..
I can open AIFF files In Samplitude.. What is the "normal"Protools format. I will be doing some things that originated in Protools and I wonder what My options are..
Thanks.
"Transformation is no easy trick: It's what art promises and usually doesn't deliver." Garrison Keillor
NelsonL
Re: Files question.
« Reply #5 on: August 19, 2005, 12:34:23 pm »
ivan40 wrote on Fri, 19 August 2005 09:09
It's user defined upon opening a new session-- seems to me that WAV and AIFF are both pretty common.
Blake
Re: Files question.
« Reply #6 on: August 20, 2005, 02:27:05 pm »
Hey Eric
I tried to do your "save as" solution, but where is the option to change file type?  It only asks where to save.
Chris Cavell
Re: Files question.
« Reply #7 on: August 20, 2005, 05:56:57 pm »
Blake wrote on Sat, 20 August 2005 13:27
Hey Eric
Not "save as", you need to use "save session copy in".  That should do it.
originalrecorderman
Re: Files question.
« Reply #8 on: August 20, 2005, 06:11:03 pm »
Eric Greedy wrote on Fri, 19 August 2005 11:39
ditto..but excuse my using the word "as" instead of "in"..my rig's at work..the old memory muscle must be weak.
Smile
Curve Dominant
Re: Files question.
« Reply #9 on: August 23, 2005, 10:09:30 pm »
Eric Greedy wrote on Fri, 19 August 2005 16:39
save session copy as.... (in)
Thanks Eric, cuz I've been wondering how to do this myself lately.
