Quote: |
... The (Schoeps) mics are exciting in that they give you what you have -- sometimes what you have (instrument/performer) isn't all that exciting. The Schoeps will tell you that. But they won't make it better...
and:
Quote: |
In fact, it is their neutrality that is their undoing. People are attracted initially to a brighter sound or a louder sound. That's just the way we're built. Schoeps just isn't that type of microphone, nor should it be to my way of thinking.
Barry, even if I overlook the seeming discrepancy between the first sentences in both of your quotes, I have a fundamental problem with the logic of your (and many others') thinking about this subject:
To me ONE very important job a good mic has to succeed in is to translate the musical event I heard with my ears well enough into the electro-acoustic realm that I can again embrace it emotionally.
I firmly believe that our hearing is so complex and refined that no microphone ever can capture what we hear, because the medium, even in its current state of the art, is too primitive.
So, let's talk here about the very best microphones, i.e. those that were conceived and executed without engineering or financial shortcuts, and therefore avoid blatant, major-league artifacts introduced by either bad capsule or bad electronic design (the Schoeps company is certainly in that category with most ot their offerings.)
This is my theory: Because the sonic truth we heard originally in the performance cannot be transmitted, we react emotionally to a certain type of acoustic/electronic manipulation by the microphone (and its associated follow-up equipment.)
If the manipulation is done well, either by design or by happenstance (As an example I am thinking of the ELA M251 in both cases), we generally will respond positively emotionally, and may even regard the recorded sound as "realistic".
If the manipulation is done without introducing specific euphemisms- done through frequency response, level and type of distortion, etc.- then we will not embrace the results emotionally.
I therefore treat the terminology of a "neutral" sounding mic with suspicion- this is invariably a mic that only intellectually convinces me- a mic so "real" that I don't even respond to it emotionally anymore.
If that is the case, the mic has no place for me in my life, because I come to recorded music for the same reason that I come to a performance: I want emotional connection to the music.
I do not want to be misunderstood: My esteemed colleagues and I are striving for ever better qualities of sound transmission in a microphone, because each and every bit of euphemism that can be replaced by a higher grade of transmission here or there in the circuit or membrane is one step closer to an emotional musical truth and satisfaction. But I still see a huge gaping hole where the mic- every mic- has to fudge, because the ear's functions are so superior.
P.S.: I hope we as professional audio enthusiasts are finally past the state where we will react positively just because a mic is brighter.
On the other hand, a brighter mic (within reason!) can 'make up' transmission losses over distance, which out ear/brain combo can effortlessly overcome.
Kind regards,
