Pages: 1 ... 22 23 [24]   Go Down
Author Topic: IC's kill music  (Read 132451 times)
compasspnt
Re: IC's kill music
« Reply #345 on: February 23, 2009, 11:10:18 PM »
garret wrote on Mon, 23 February 2009 22:54
Hey, anyone hear any good songs lately?
I might have, if IC's hadn't killed all of them.
zmix
Re: IC's kill music
« Reply #346 on: February 24, 2009, 06:32:10 PM »
Wait wait wait wait....
I know about "Mr. Yuk":
http://tbn1.google.com/images?q=tbn:Pwa15zde4VBd7M::http://www.asmalldoseof.org/historyoftox/1970-2006/Mr.YUK2.jpg
But what are these "ICs" (pronounced "Ick")?
Are these "ICs" = Home Taping?
http://upload.wikimedia.org/wikipedia/en/b/bc/Home_taping_is_killing_music.png
or are these so called "ICs"  = Illegal downloading?
http://www.gothtronic.com/Goth/data/Articles/DOWNLOADING_KILLING.jpg
Tomas Danko
Re: IC's kill music
« Reply #347 on: February 25, 2009, 06:10:42 AM »
Let's add some more then, shall we.
http://funny.williepedia.com/wp-content/uploads/2007/11/downloading_communism.jpg
zmix
Re: IC's kill music
« Reply #348 on: February 26, 2009, 01:25:37 AM »
Are there "ICs" in communism, too?
garret
Re: IC's kill music
« Reply #349 on: February 26, 2009, 03:14:14 AM »
zmix wrote on Thu, 26 February 2009 00:25
http://www.smh.com.au/ffximage/2005/02/04/icon_topic3_feb4,0.jpg
"IC's are killing capitalism!"
tomorrow is already here - http://www.worksongs.net/
zmix
Re: IC's kill music
« Reply #350 on: February 26, 2009, 08:57:49 AM »
Fight the REAL enemy:
http://bigearflux.files.wordpress.com/2008/02/gdfghdfghdfghfghkilling_music.jpg
compasspnt
Re: IC's kill music
« Reply #351 on: February 26, 2009, 09:25:18 AM »
O, I C.
Larrchild
Re: IC's kill music
« Reply #352 on: March 05, 2009, 10:43:20 PM »
index.php/fa/11548/0/
Larry Janus
http://2ubes.net
Andrew Hamilton
Re: IC's kill music
« Reply #353 on: March 11, 2009, 01:50:02 AM »
Here's what Dan Lavry posted on his own web site 3 years ago:
"The Opamp approach has some advantages over discrete. The component matching capability is great, and one can match more then 2 devices, you can match dozens. Also, the ability to have everything packaged in a tiny area makes all the devices operate at the same temperature which further help greatly.
But Opams have their limitations as well, compared to discrete circuits. First, there are no inductors. Second, the capacitors used in the silicone are limited to very small values (the area is tiny). The caps are also limited in the type of material (fro example, no film type caps and so on…) Last but not least, most opamps are designed for relatively low current, thus limiting the applications when very high current is required. The same is true for voltage. Let me note that some companies specialize in manufacturing high voltage and current devices…
Some of the shortcomings of the opamps are overcome by using them with external parts. Often there are compensation pins on an opamp, enabling the designer to “continue” and “complete” the circuit inside the silicon with external parts. Often a designer can extend the usability of an opamp by use of external parts to cover high voltage, current and power applications, improve the input circuitry and so on…
But at the end of the day, the opamp is a repackaging job, and any comments against an opamp should be viewed as such. I am not for or against opamps. It is just one more part type, and one can and should use it were it makes sense. And one should not use it where it does not make sense. I would not “judge” the quality of a piece of gear based on use (or lack of use) of amps."
Andrew
www.serifsound.com
premastering for CD and DVD-A.  Featuring FTP load in and delivery as well as analog tape transfers.
MDM,
Re: IC's kill music
« Reply #354 on: March 23, 2009, 07:23:57 AM »
an opamp is not a repackaging job..
it is a miniaturization...job... with all the shortcomings you would expect from it.
as Dan Lavry mentioned, they are easy to use also because they do not need expensive selection.
I must study politics and war that my sons may have liberty to study mathematics and philosophy .. in order to give their children a right to study painting, poetry and music.
John Adams (1735-1826) 2nd President, United States
Andrew Hamilton
Re: IC's kill music
« Reply #355 on: March 26, 2009, 01:56:30 AM »
MDM, wrote on Mon, 23 March 2009 07:23
...and some ancillary benefits to the diminutive size, as well!  Don't just throw a baby out with the bathwater. Smaller is better because it is more portable and takes up less space. As mentioned in the quote, the very nature of the silicon chip enables a high level of uniformity to its electrical and thermal properties.  The drawsback to ICs, which he does cite, can be worked around, and this extra effort (say, adding larger parts to the build-out pins) is worth while because of the low cost and various conveniences (thermal, spatial, and precise) of using little ICs for the sections that benefit from them (or are immune to their erstwhile drawsback).
Andrew
www.serifsound.com
MDM,
Re: IC's kill music
« Reply #356 on: March 31, 2009, 06:46:53 AM »
I think thermal distortion is something you want to look at.
that and the fact that IC's cannot use selected components like discrete circuits can, therefore they are designed with a lot more error-correcting circuitry than you'd need with a properly-designed purpose-built discrete circuit.
Jim Williams
Re: IC's kill music
« Reply #357 on: May 14, 2009, 11:09:59 AM »
JGreenslade wrote on Tue, 10 May 2005 02:46
The Jensen 990 looks pretty discrete to me.
See what you think, I have attached a schematic.
Justin
edit: The schematic is shown for informative reasons, I'm not trying to patronise anyone saying it's "discrete" Smile
Front end = LM394CH super matched transistor pair, in other words, an IC. It also sounds like crap, a MAT 02 or the that part is superior, pop one in your SSL 4k mix amp and report back.
It's not the arrow, it's the indian.
Jim Williams
Audio Upgrades
Jim Williams
Re: IC's kill music
« Reply #358 on: May 14, 2009, 11:15:40 AM »
MDM, wrote on Tue, 31 March 2009 03:46
You really need to talk to a chip designer. You are full of missinformation. New devices from Analog Devices are based on thermal and layout matching on a precision level not attainable with discrete components.
Can you show me a discrete opamp that does 1.6 ghz?
Can you show me a discrete that does -154 dbu THD?
Can you show me a discrete opamp that does .8 nv/hz/sq noise?
Jim Williams
Audio Upgrades
Pages: 1 ... 22 23 [24]   Go Up
Page created in 0.095 seconds with 19 queries.
