I've found that certain 110Ω digital audio cables can be microphonic in certain audio applications (load-impedance can surpress this effect to a greater or lesser extent) but generally, copper (and lots of it) is good, becoming of increasing importance where the load impedance is lower. Capacitance is bad, becoming of increasing importance where the source impedance is higher. Inductance is bad, becoming of increasing importance where the load impedance is lower.
I keep coming back to the same point: Optimizing the cable is best done when knowing the application. After talking about cable capacitance NOT being a problem for many audio applications (low impedance driver and high impedance load) I see it being interpreted as “go for low capacitance” or as “use digital audio cables”.
I think people prefer to not be bothered with having to think learn and think about details. It unfortunate, because there is no such thing as “one shoe fits all”, nor is there “one cable fits all”.
Your comment about microphonics is a good example. A cable carrying DC signal can respond electrically to mechanical disturbance (such as tapping or moving). The mechanism is similar to the operation of a condenser mic – parallel pieces of metal (2 wires or a wire and shielded) are in fact a capacitor. A DC charge on a cable between the conductors will generate an ac (signal) voltage when one changes the distance between the conductors, such as when tapping on the cable.
Normally, such microphonics is more offensive when the signal level is low and will be amplified (such as cables for microphone applications). It is wise to avoid DC on cables but in some cases such as condenser mics there is a lot of DC (48V), thus no escape from DC. So a more “solid” cable may be of benefit for high DC voltage case. Again, one can approach or supplement a solution for DC micophonics by protecting the cables from mechanical motion.
The other factors affecting the DC voltage microphonics are the parallel combination of source resistance and load resistance. If we have low impedance (resistance) than the ac voltage due to mechanical motion (microphonics) will be lower amplitude. But it is best to have a low source resistance, and a high load resistance. Adding additional load is not very effective, because the discharge path for the audio signal is almost completely determined by the much lower impedance at the source side (often in the 75 Ohms range), unless you are ready to go to very low resistance load (very bad idea in general).
There are other factors impacting DC voltage microphonics, mostly mechanical. Generally speaking you want a cable with a greater distance between the conductors, and the material to be of low dielectric constant. These are the same factors that make for low capacitance cable. Low capacitance tends to yield low “change in capacitance” due to mechanical causes. We want to minimize the change in capacitance. And of course, as always, the longer the cable, the more charge thus the more microphonics…
Regards
Dan Lavry
