Author Topic: What type of U47 cable is this?  (Read 491 times)
Gnas
  • Real Full Name: Harry Cook
« on: March 01, 2024, 04:19:42 AM »
Hi,
Anybody or Klaus knows what type of U47 cable is this? Is it the original rubber cable, same as the thick black rubber one?
I attached the pictures.
Thanks!
klaus
Re: What type of U47 cable is this?
« Reply #1 on: March 01, 2024, 12:44:17 PM »
It is not the first generation cable with the rubberized jacket and four rubberized and colored conductors
But it may be from the second generation, depending on the actual color of the jacket, which you did not mention (the photo shows it as tan-brown).  The construction and colors off the individual conductors would give further clues.
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
Gnas
« Reply #2 on: March 01, 2024, 01:40:08 PM »
Ah Ok, thanks Klaus. I can't look at the conductors, but knowing it's not the first generation one is sufficient.
Kai
« Reply #3 on: March 05, 2024, 06:29:42 PM »
When intending to use old cables, have a closer inspection if they are still intact.
Quite often the shield (that serves as ground link too) has many or all wire strands broken, specifically near the connectors where the stress is higher. This might cause all types of problems like noise and crackling.
The best check is resistance measurement with an Ohm meter on all conductors and shield.
The results should be reasonable and uniform (considering length and gauge) and most important, resistance should not change when the cable is moved / shaken.
afterlifestudios
  • Real Full Name: John Raham
« Reply #4 on: March 06, 2024, 12:07:04 PM »
Very true.  I had to chop a few feet off each end of my sm69 cable and redo the connectors because of exactly this...
Page created in 0.161 seconds with 22 queries.
