Author Topic: vocal with piano  (Read 1213 times)
wildplum
  • Real Full Name: paul tumolo
vocal with piano
« on: September 20, 2004, 05:49:04 PM »
In interviews, both Al Schmitt and Ed Cherney mentioned using similar systems for achieving an acceptable amount of isolation while recording a singing pianist (Dianna Krall and Nora Jones). The key to the system seems to be using a large piece of "foam" (12 inches thick according to one of them) and draping blankets over the foam and piano (I assume on a full stick, using the top to support the blankets).
I am interested in learning more details about this technique. Also, any other tips on managing bleed in a singing pianist situation
Paul Tumolo
<a href="http://www.wildplum.org" target="_blank">Wildplum Recordings</a>
a micro label, studio and remote recording service
hargerst
Re: vocal with piano
« Reply #1 on: September 23, 2004, 10:22:09 AM »
wildplum wrote on Mon, 20 September 2004 16:49
You can always use the trick of a figure 8 sideways to null the vocals and pick up just the piano, and another very directional mic to get just the vocals.
Harvey "Is that the right note?" Gerst
Indian Trail Recording Studio
20to20
« Reply #2 on: October 07, 2004, 11:57:19 PM »
I'm not Al or Ed but here are
some approaches that I use:
After positioning the mic(s) inside the piano,
I lower the lid to rest on a foam block
then I drape heavy blankets over the lid ...
I use a big (14"x8"x4") chunk of laminated
packing foam to prop the lid open just a few inches...
Don't use the piano's stick at all...
For mics, I'll often use two Earthworks (QTC-30's)
positioned perpendicularly to the piano's soundboard...
The mics are placed down into 2 of the 4 holes
that were cast into the piano's iron frame,
a mere 3mm to 6mm above the soundboard...
These locations are infinitely variable, but after
many experiments, I've developed some favorite spots...
_____________________________________________________
Then I usually close-mic the vocalist with a cardioid LDC...
I've also had good results with some singers using a Royer 122,
but to help with the separation I rigged up an Auralex
"scrapbaffle" behind the mic (between the mic and the piano)...
Good luck/Have fun,
Bob Phillips
20to20soundesign
Page created in 0.087 seconds with 22 queries.
