Author Topic: Source For Tuchel Connectors For A Vintage Neumann M249 Mic?  (Read 430 times)
brucekaphan
« on: February 13, 2024, 07:10:39 PM »
Is anyone aware of a source for the Tuchel connectors on both ends of a vintage M249 to NN48h power supply cable (as in the two photos I've uploaded)?
klaus
Tuchel was bought by Amphenol decades ago, which then promptly discontinued the whole microphone connector line.
But if you do a search for Binder 09-0042-00-07 you will find lots of buying options. The female equivalent is also available.
Binders are the only choice these days for Neumann microphone applications. The plastic is a bit softer, so be careful with your solder iron.
By the way, Neumann uses the males and females on their U67 Reissue, after modifying the key slot position.
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
brucekaphan
Re: Source For Tuchel Connectors For A Vintage Neumann M249 Mic?
« Reply #2 on: February 14, 2024, 09:13:33 PM »
Klaus, you never disappoint. Thank you for hosting this forum and for being so generous with sharing what you know. For others on the same search, I'm reasonably certain that this is a full description from their catalog:
Binder M25 Male cable connector, Contacts: 7, 5.0-8.0 mm, shieldable, solder, IP40
SKU: 09 0041 00 07
Binder M25 Female cable connector, Contacts: 7, 5.0-8.0 mm, shieldable, solder, IP40
SKU: 09 0042 00 07
Page created in 0.026 seconds with 21 queries.
