Author Topic: U67 PSU - Recap  (Read 916 times)
klaus
Re: U67 PSU - Recap
« Reply #15 on: September 21, 2022, 01:24:40 PM »
1. As a friendly reminder: only real posters who identify themselves with their real name are allowed to post here.
"Il Caccillo" does not sound like a real name to me. I apologize should I be wrong and indeed names like that are printed in passports.
2. What have you actually learned from the responses you received? It seem to me that you ended up where you started out: replace what seem perfectly fine filter caps in a vintage collector's item worth now thousands of dollars, possibly reduced in value by these alterations.
Again, please correct me if I got this wrong, but were these exchanges over the last month worth the time and space they occupy?
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
RuudNL
  • Real Full Name: Ruud van Steenis
  • There is a solution for every problem!
Re: U67 PSU - Recap
« Reply #16 on: September 22, 2022, 10:35:40 AM »
The only thing I can add to the discussion about replacing capacitors in microphone power supplies, is that I have replaced the capacitors in a couple of U47 (VF14) power supplies.
These power supplies had developed a significant mains hum, caused by the leak currents of the capacitors.
With the new capacitors, the microphone output is totally hum free now!
(And yes, I agree that you shouldn't replace things just for the sake of replacing them.)
klaus
Re: U67 PSU - Recap
« Reply #17 on: September 22, 2022, 12:11:43 PM »
As there is a high quality screw-in, German-made substitution available for NG filtering, the value of the power supply will not suffer as a consequence of replacing filter caps.
If one suspects failure, a simple test is to remove one lead of each of the five capacitors, put it on a capacitance meter and check overall capacity.
if any of them falls below the rated capacitance (47mfd) replace.
Klaus Heyne
German Masterworks®
Page created in 0.056 seconds with 23 queries.
