February 08, 2023, 03:27:49 PM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
R/E/P
Klaus Heyne's Mic Lab
(Moderator:
klaus
Lacquer sealing (Conformal Coating) of Capsule Components
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Lacquer sealing (Conformal Coating) of Capsule Components (Read 397 times)
gtoledo3
Full Member
Offline
Real Full Name: George Toledo
on:
June 22, 2022, 11:55:29 AM »
It was just popping out to me that it appears that at some point the capsule ring on Neumann mics appeared to be sealed with conformal coating, but that now it doesn’t appear to be.
Any thoughts on this?
I am also wondering; does Neumann still use a totally uncoated backplate or have their been any updates to use any sort of coating substance to protect the diaphragm if it hits the backplate.
klaus
Moderator
Hero Member
Offline
Re: conformal coating and backplate coating
Reply #1 on:
June 22, 2022, 01:12:39 PM »
Unlike AKG, Neumann has never used coating to reduce electrostatic attraction between diaphragm and backplate. To keep the two closely spaced planes apart, Neumann uses a different method since introduction of the second K87 generation.
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
gtoledo3
Full Member
Offline
Reply #2 on:
June 22, 2022, 02:54:05 PM »
There appears to be a lacquer used to seal the outer mounting ring screws on many Neumann capsules, but I *think* there no longer appears to be?
I believe it to have been something along these lines:
https://www.amazon.com/gp/product/B07B8RY7M6/ref=as_li_tl?ie=UTF8&camp=1789&creative=9325&creativeASIN=B07B8RY7M6&linkCode=as2&tag=debriscom&linkId=27726d72a7ec9a306f656b05087e5264
It first got on my radar from reading about Bock adding conformal coating to capsules (at some point), and wondering what that meant.
gtoledo3
Full Member
Offline
Reply #3 on:
June 22, 2022, 02:55:06 PM »
Mic Parts dot com also mentions using it to seal solder joints.
https://microphone-parts.com/pages/diy-tools
klaus
Moderator
Hero Member
Offline
Reply #4 on:
June 22, 2022, 03:07:38 PM »
Thanks for the clarification.
On center-terminated capsules, like Neumann's, the sealing of diaphragm and backplate assembly screws prevents premature moisture backdown and shorting of the capacitance between diaphragm and backplate., especially when contamination is present.
Neumann still uses sealing lacquer (less fancy name for "comformal coating") on capsules, but it's sporadic, really thin and barely noticeable.
Klaus Heyne
German Masterworks®
gtoledo3
Full Member
Offline
Re: Lacquer sealing (Conformal Coating) of Capsule Components
Reply #5 on:
June 22, 2022, 04:44:18 PM »
Ah, ok. I did think I saw something, just not the very obvious amount on certain era. Thanks, Klaus.
Print
Pages: [
1
Go Up
« previous
next »
R/E/P
(Moderator:
klaus
