Author Topic: U87Ai Circuit Versions Explained  (Read 4669 times)
klaus
« on: October 18, 2020, 02:14:27 PM »
I had mentioned the U87Ai circuit changes in previous posts here and there.
Here is a comprehensive chart that you can copy and save, so you will know which circuit is in your mic (silver sticker with circuit # is on the back of every transformer):
Circuit Diagrams:
02: Standard-U87A Neumann (FET: 2N3819 or similar, selected)
03: DC/DC-converter board: omit U89 components (from ~1995)
04: PCB 4 in place of discontinued FET (from 2002 to 08/2013)
05: 2 values of components on DC/DC-converter board changed (2011)
06: return to single FET in place of daughter board PCB 4; DC board
same as 03, plus changes from 05. (since 08/2013)
As you can see, ONLY #04 and #05 have the dreaded "daughter" board installed, instead of the single FET.
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
RuudNL
  • Real Full Name: Ruud van Steenis
  • There is a solution for every problem!
Re: U87Ai Circuit Versions Explained
« Reply #1 on: October 19, 2020, 03:56:19 AM »
I think you mean 2N3819, not SK.
Thanks! Corrected. KH
afterlifestudios
  • Real Full Name: John Raham
« Reply #2 on: October 24, 2020, 01:47:08 PM »
Thanks.
skrimoblee
  • Real Full Name: Jake Kruer
« Reply #3 on: April 04, 2023, 01:44:24 PM »
Will someone with experience share their preference and describe the sound of u87Ai's with circuit versions 02 and 06.
https://gearspace.com/board/high-end/1278068-u87ai-difference-different-vintages.html
