Author Topic: UM 92.1S Mod?  (Read 1352 times)
Mishro
UM 92.1S Mod?
« on: February 02, 2019, 12:49:23 pm »
Could anyone who has completed the Archut mod to the MG UM 92.1S please comment on how it changed the sound of the mic?
To me, stock, it has strange artifacts in what I think is the upper mids.  I can only describe it as a distortion that is a little sizzly. It should be noted that I am a sibilant vocalist (high tenor) and I shot it out over 2.5 months against many other high end mics. It was the most tame in the highs and clear in the mid's for my voice. Probably about 20 or so in all. I could provide a list but I don't want to derail this thread or provide additional irrelevant info.
My final contenders were a Manley Reference Silver, Vintage UM 57 and the UM 92.1S. There were others that I liked but they either exceeded my budget and/or weren't quite right for me.
I am in Long Island, NY and I am considering the mod?  Any recommendation's for a good tech to do the work?
I can PM a more extensive list if anyone wants to fall asleep.
Thanks.
klaus
Re: UM 92.1S Mod?
« Reply #1 on: February 02, 2019, 02:32:37 pm »
I am familiar with the circuit changes Oliver came up with. They are an audible improvement and have been widely discussed on Gearslutz and DIY forums.
But I caution you investing in a modification of this mic unless you are certain that the aggressive mids and sibilance you complain about are not the result of the post-2000 PVC formula that's been used by MG on all their M7 capsules for more than a decade now.
I personally find these capsules too sibilant and mid-forward, and they remind me how brilliant MG's M7 capsules used to be until the change-over.
So, unless you own a very early U92.1S, you may want to reconsider pursuing a modification.
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
Mishro
Re: UM 92.1S Mod?
« Reply #2 on: February 02, 2019, 07:14:24 pm »
Hi Klaus,
Thank you for your reply.
My Um 92.1S is new, purchased within the last few months.
If I am understanding you correctly, the PVC formula changed after 2000, thus affecting the finite details of the sound of the mic's capsule. It contributes to the brightness and forward mids. Thus am I to consider that some of the artifacts I am hearing may actually be the result of changes made to the actual PVC of the M7. I'm sure it's probably been discussed as to why the formula was changed (I am assuming capsule longevity or regulatory management) but if it isn't broken, why "fix" it?
At any rate, it sounds as if the mod will help to tame these issues.
Thank you again.
M
klaus
Re: UM 92.1S Mod?
« Reply #3 on: February 03, 2019, 12:23:05 am »
Hi Klaus,
(...) I'm sure it's probably been discussed as to why the formula was changed (I am assuming capsule longevity or regulatory management) but if it isn't broken, why "fix" it?
The formula was changed due to government regulations: the old type PVC used chemicals in the process of manufacturing diaphragms which were deemed highly toxic to anyone working with them repeatedly. As far as I know, longevity was not affected or improved.
The mod will improve the sound of the mic, but with a compromised capsule as front end, its shortcomings can only be modestly mitigated with a modified processor.
Klaus Heyne
German Masterworks®
Mishro
Re: UM 92.1S Mod?
« Reply #4 on: February 03, 2019, 07:08:32 am »
Thanks Klaus albeit somewhat frustrating.
Mishro
Re: UM 92.1S Mod?
« Reply #5 on: February 03, 2019, 08:28:31 am »
Hi Klaus,
I figured I'd throw this out there.
Would a capsule reskin fix the issue? Any recommendations and material specs? Would it be worth it?
Thanks.
klaus
Re: UM 92.1S Mod?
« Reply #6 on: February 03, 2019, 12:52:59 pm »
A "reskin" (re-diaphragming) of your MG M7 will not make your situation better, but likely worse.
Aside of Siegfried Thiersch, whose current M7 efforts are roughly equal to those of MG, there are to my knowledge no third-party providers who have the skills to put a PVC diaphragm on an M7, with an acceptable result.
Klaus Heyne
German Masterworks®
Mishro
Re: UM 92.1S Mod?
« Reply #7 on: February 03, 2019, 03:09:59 pm »
Thanks Klaus. Good information.
Mishro
Re: UM 92.1S Mod?
« Reply #8 on: March 17, 2019, 10:34:37 am »
Hi Klaus,
I have been doing some research.
So I guess I should clarify that after some heavy listening this mic indeed sounds good on my voice.  The upper midsized are a bit prominent but I think it is preferable for my voice.  However, there is a little nasality and the sibilance I can remove with the de-esser on my SPL Channel One.
There is a little bit of nasality (slight , not overwhelming) that I am wondering if it can be removed main mods to the mic. I guess that congestion is what is bugging me most.
Thank you in advance for your reply.
