Author Topic: consequences of incorrect plate voltage  (Read 1404 times)
Brian Campbell
  • Real Full Name: Brian Campbell
« on: June 24, 2018, 05:39:26 PM »
What are the effects of incorrect B+/plate voltages with regards to frequency response?
Is there a general guideline of tolerances?
klaus
Re: consequences of incorrect plate voltage
« Reply #1 on: June 24, 2018, 05:45:03 PM »
Plate and B+ voltages are not necessarily interrelated. Bad tubes will cause low plate voltages, even if B+ is correct.
On the other hand, extreme B+ variations-too much or too little- will cause capsule distortion or noise, because capsule polarization voltage is usually divided off the B+ supply voltage. Here, even just a few more volts deviating in either direction will cause audible artifacts.
None of this answers your question. I have not experienced frequency deviations, because the other effects of too litte or too much B+ and plate voltages are overwhelming.
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
Page created in 0.05 seconds with 23 queries.
