Author Topic: Neumann U48 Nuvistor Reversal to VF14  (Read 3560 times)
musicalnyc
  • Real Full Name: Peter Lerman
« on: February 15, 2018, 11:43:54 pm »
I have a Neumann U48 that was converted to Nuvistor long ago via the AR47 plug-in.  I would like to restore it to VF14 specs and I am aware that I need to modify the power supply.
Is there anything within the microphone itself that needs to be adjusted or modified (besides swapping the AR47 with a VF14) in order to reverse it to stock?
Thanks for your help!
klaus
Re: Neumann U48 Nuvistor Reversal
« Reply #1 on: February 16, 2018, 01:44:24 am »
Hello Peter,
The advantage of the AR-47 Nuvistor plug-in: no additional changes inside the mic are necessary to re-convert to VF14 once the plug-in is removed. The mic will be 100% stock again.
The required higher Nuvistor voltage of 110VDC was obtained by replacing one of the four 1KΩ dropping resistors  in the original NG power supplies with a wire bridge, and placing that resistor in parallel with an existing one.
Once the wire bridge has been removed and the resistor soldered back in its place again (by a qualified technician, of course!) the NG is also back to stock, ready to power a VF14-equipped U47/48.
When it's done, it will look like this:
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
musicalnyc
Re: Neumann U48 Nuvistor Reversal to VF14
« Reply #2 on: February 16, 2018, 09:07:05 am »
That's great to know.  Thanks, Klaus!
