(...) The U 67 amplifier's gain at 16 kHz is specified at 7 dB below its gain at 1 kHz(...)
That correlates to my measurements of the K67/87capsules without high frequency compensation: they are up a whopping 8-9dB @ 8kHz. I never understood why people thought it would be an improvement of U67 or U87 mics to remove the high frequency attenuation in the processors. Bright only feels better for about ten seconds. After that, you need Advil®.
Which are those NOS tubes you would purchase?
That a K67 capsule is too bright without attenuation, and that my work on your U67 ended up being too bright for your taste are unrelated. I would never release a U67 without high frequency attenuation. In your case, it must have been my interpretation of what constitutes a reasonable amount of high frequency content in the balance. According to my records, it's been 23 years since I worked on your U67, and I apologize that I do not recall your dissatisfaction with the top end, to the point that you sold the mic.But to hear of such outcome is extremely disappointing to me*, even after more than two decades have passed, because I pride myself of following up with my work until every client is truly satisfied with the result - one more reason I give an unconditional warranty on my work. *It's especially disappointing, because readjusting the attenuation in a U67 is about as easy as it gets.
Thanks for clarifying. I indeed interpreted the high frequency response of condenser mics I modified hotter in the last century, to compensate for the cumulative high end loss of 24 track recording especially when two of these machines were often linked in the 1980s and 1990s to get 48 tracks.Best,KH
