Author Topic: Neumann U67 C9 capacitor.  (Read 4406 times)
SDVIG
  • Real Full Name: Sergey Kazantsev
« on: November 12, 2017, 07:56:51 AM »
Dear Claus.
I am very grateful to you for your help.
Your advices help me a lot.
I want to ask you a question about the problem with my microphone U67. I'm familiar with a skilled craftsman. He is known as one of the best masters in musical audio equipment. For example, it can parse and compile SSL 4000. But he is not a specialist in microphones. Now to the point. I feel my microphone is losing the low end. The master tells me that the capacitor C9 is responsible for this. When we extracted it from the microphone, the capacity was normal(Capacitance is OK). But the master does not have a stand in order to test this capacitor. If we did not have a capacitor of a suitable size, we put two capacitors with a superior capacity of 4 times. These capacitors have a voltage of 200 volts. Master said that this is dangerous for the microphone. With the audio test, the microphone received a low end, but the sound turned out to be harsh. Please advise which film capacitor should be placed in the microphone?
At the second edition of U67, Neumann used film capacitors.
I see such suggestions on Ebay:
MKC 1860 250V 0.47uF 474 10% HV Non-polar Film Capacitor:
https://www.ebay.com/itm/1lot-6PCS-ERO-MKC-1860-250V-0-47uF-474-10-HV-Non-polar-Film-Capacitor/181834945143?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
 CAP, FILM, PET, 470NF, 250V, AXIAL MKT1813447255G By VISHAY
https://www.ebay.com/itm/1-X-CAP-FILM-PET-470NF-250V-AXIAL-MKT1813447255G-By-VISHAY/192229054155?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
1. Could you advise me how to act?
2. Why is the U67 Schematic talking about 250 volts, but in reality I saw in several microphones 350 volts?
3. Maybe it's not a condenser?
PS: Any advice is welcome.
Second edition of U67: & My capacitor:
klaus
Re: Neumann U67 C9 capacitor.
« Reply #1 on: November 12, 2017, 12:23:14 PM »
I am dubious that the original electrolytic 0.5mfd cap is your problem. It never has, during all my years of attending to U67. But there could of course always be a first.
Did you measure it outside the circuit? Every half-decent meter these days has a capacitance tester built in. I want you to conform that it measures low before you move on.
As to voltages in a replacement: You can safely install a film & foil polypropylene capacitor with 0.5mfd capacitance and 200VDC rating, as long as it fits. I would not use inferior material in this position as it's decoupling DC from audio going into the transformer.
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
Kai
« Reply #2 on: November 13, 2017, 04:11:42 PM »
Klaus, are you sure 200V rating is enough?
On start, when the tube is not already active and conducting, the voltage is a bit higher.
I see 225V B+ with NU67 PSU at nominal lines voltage.
I'd go for at least 250V for this cap, although PPs usually have some safety margin.
For an electrolytic I'd stay with 350V.
Testing the electrolytic with a normal multimeter cap tester doesn't tell the whole story, because DC leakage is not tested, which may lead to a bad low frequency response due to biasing the transformer.
klaus
« Reply #3 on: November 14, 2017, 12:11:40 AM »
Yes, plenty, and for the reason you mention: safety margin of f & f caps.
I have never had a failure in all the years I have installed them. Besides, there is too little space in that mic for a larger physical size with a higher voltage rating without sacrificing quality.
Klaus Heyne
German Masterworks®
ilcaccillo
  • Real Full Name: iL Caccillo
« Reply #4 on: July 25, 2022, 12:46:31 PM »
Hello Klaus,
I also think that 200V it's a low rating for this cap,
at power up I can measure the B+ voltage starting at around 270V to 260V until reducing and becoming stable at 210V,
So if C9 is rated at 200V it will be stressed a lot at each power up before the tube is conducting.
In my case seems even that 250V might be too low, maybe that's the reason Neumann used 350V rated caps in the mics (although schematics state 250V)
Don't you agree?
Thank you so much
Page created in 0.07 seconds with 24 queries.
