Author Topic: Odd ball idea for MS technique  (Read 5605 times)
John Marsden
  • Real Full Name: John Marsden
« on: October 20, 2017, 12:18:40 am »
Daft question
If I point two small inch condenser mics away from each other  (Rode M5s)
and then point a third microphone forwards at 90 degree to them (Rode NT2-A)
Can I use this as a sort MS arrangement? I know its not really what you should do. But just thinking of a back up plan if one of my two NT2s should fail (ie get stolen!)
Ie do the two M5s almost equal a figure of 8 arrangement  And given that can I just pan them right and left and use them to add wide stereo sound.
And then I got to thinking can I make the front mic xy and place a pair of mics pointing off to the right and left to create the wider ambient field.
Aim to use for classical trio or piano ensemble stuff in a hall.
Thanks to anyone with a suggestion
John
Dinogi
  • Real Full Name: Dean Giamette
  • Wow! A third star! I'll try to be worthy of it.
Re: Odd ball idea for MS technique
« Reply #1 on: October 20, 2017, 04:04:15 am »
To be a proper MS you would need to flip the polarity of one of the side microphones. Otherwise it won't cancel when collapsed to mono.
I'd trade everything I own now for a good sounding room and a bucket of 57's.
John Marsden
« Reply #2 on: October 23, 2017, 10:27:25 pm »
I should try to align the mic diaphragms in the same plane so they will have no delay issue.
Would the fact they are pointing 180 from each other then mean they are already out of phase?
I shall try both and see which gives the best mono response.
Thanks for the advice
Dinogi
« Reply #3 on: October 24, 2017, 03:38:07 am »
Actually, no. The outputs of your side mics would be still in phase and would be additive when they should cancel. That's basically the point of the MS technique. More than other techniques, MS seems to be an auditory illusion and not a verbatim reproduction of what happens in front of the mic's.
Fletcher
« Reply #4 on: October 24, 2017, 09:41:36 am »
M/S... you're taking a figure 8 mic, splitting the signal [as there is only one output], taking that signal and flipping one side 180˚ out of polarity with the other side so -- when of equal level and put in mono, the two sides of [the identical signal] will cancel... the forward facing cardioid microphone being unaffected by the polarity reversal.
Even if RDE built 100% "perfectly matched" microphones -- due to placement [spacing between the two capsules] they would never cancel 100%... they might get "close enough for jazz", but they will never 100% cancel.
This is not to say you shouldn't try the technique [who knows, it could be awesome for your application(s)], but it will NEVER be true "M/S".
Peace
CN Fletcher
"Recording engineers are an arrogant bunch
If you've spent most of your life with a few thousand dollars worth of musicians in the studio, making a decision every second and a half... and you and  they are going to have to live with it for the rest of your lives, you'll get pretty arrogant too.  It takes a certain amount of balls to do that... something around three"
Malcolm Chisholm
Alisatralp
  • Real Full Name: Maryamtive
« Reply #5 on: April 26, 2018, 11:41:57 pm »
I have a simple sketch of the setup Id like to try. I was gonna try an MXL 990 for vocals, and a couple of SM57s for side instrument mics. Shuold we make a date for your practice space?
sdelsolray
  • Real Full Name: Steve Boyke
« Reply #6 on: April 30, 2018, 09:47:06 pm »
Not exactly, if you want to approach/emulate M/S.  Both side cardioid mics must first be mixed together.  That mixed track is copied/dupicated.  The mixed tracks are panned hard left and right.  One of the mixed tracks would have the polarity reversed.
An issue not yet discussed which makes using two cardioid mics (instead of the Figure 8 mic) more different for M/S is that the null at 90 degrees on a figure 8 pattern is many dB less than the null of the cardioid mics at 90 degrees.  If a pair of cardioid mics are used, the null sides have higher amplitude which is what the mid mic is supposed to capture and the result is less distinct separation.
nancy87
  • Real Full Name: Sapna Singhal
« Reply #7 on: October 15, 2019, 04:23:33 am »
The weirdo strategy was first utilized in occasion related potential (ERP) look into by Nancy Squires, Kenneth Squires and Steven Hillyard at the UC San Diego.[1] https://treatmentforschizophrenia.com/causes
In ERP look into it has been discovered that an occasion related potential over the parieto-focal region of the skull that normally happens around 300 ms after upgrades introduction called P300 is bigger after the objective boost. The P300 wave possibly happens if the subject is effectively occupied with the undertaking of recognizing the objectives. Its abundancy changes with the unlikelihood of the objectives. Its inertness shifts with the trouble of segregating the objective upgrade from the standard stimuli.[2]
Recognition of these objectives dependably brings out transient movement in prefrontal cortical areas. Estimating hemodynamic mind action in the prefrontal cortex utilizing useful attractive reverberation imaging (fMRI) uncovered that the dorsolateral prefrontal cortex is related with dynamic changes in the mapping of boosts to reactions (for example reaction techniques), freely of any progressions in behavior.[3]
Since P300 has been demonstrated to be a consideration subordinate intellectual part in alertness, one may assume that it would be missing during rest; a period wherein data preparing of outer upgrades is ordinarily thought to be repressed. Research to date demonstrates that P300 can be recorded during the change to rest and after that returns in REM rest. Improvements that are uncommon and nosy are bound to evoke the exemplary parietal P300 in REM rest. There is, be that as it may, next to zero inspiration at frontal destinations. This is predictable with mind imaging ponders that show frontal deactivation is normal for REM rest. These discoveries demonstrate that while sleepers might have the option to recognize boost abnormality in stage 1 and REM, the frontal commitment to awareness might be lost.[4]
nancy87
« Reply #8 on: June 07, 2020, 04:58:42 am »
PatchCAD Patchbay Design and Labelling Software. Design beautiful and accurate patchbay systems within minutes using the new and improved PatchCAD 2. [https://www.youtube.com/watch?v=PYvkCvVUKJk]how to brush teeth for small kids[/https://www.youtube.com/watch?v=PYvkCvVUKJk]
