Pages: 1 [2] 3  All   Go Down
Author Topic: 7 Mics for Kim Jong Un - Why? What are they?  (Read 35627 times)
hugovanmeijeren
  • Real Full Name: Hugo van Meijeren
Re: 7 mics for Kim Jong Un - why? what are they?
« Reply #15 on: May 23, 2016, 08:24:22 AM »
I own both the M201N(C) as well as the M201TG. The same goes for the M88N(C) and M88TG.
I have not heard any sonical differences between the M201N(C) and M201TG, as far as I can tell, they sound truly identical.
For the M88 on the other hand, it's a different story. There is indeed a rather large difference between the M88N(C) and the M88TG. To my ears, the M88TG pronounces the low end in a rather unpleasant way, it is not smooth by any means. It is also much more sensitive to plopping noises (likely due to the windscreen that relies on a foam insert, instead of the triple metal mesh of the M88N(C)). The M88N(C) has a less pronounced low end and has a much smoother sound all together. It is still very good at reproducing bass instruments though.
Back on topic: I have also wondered why they chose the M201 in North Korea and was maybe even more interested in what the people of Beyerdynamic think of this.  ;) Personally I don't think the M201 is a bad choice for reproducing speech at all, I think it can work perfectly well for that purpose. The only thing is that you shouldn't use more than 1 microphone at a time... But hey, it looks very cool to stand in front of that many microphones.  8)
John Willett
  • Real Full Name: John Willett
« Reply #16 on: June 11, 2016, 12:51:19 PM »
Might be he wants a sound "larger then life" or just something different from the crop.
If all mics are used, there are certainly some sound colorations due to phase cancelations that change when he moves around.
Like a multistage Phaser FX.
Gefell builds a condenser mic line array to improve directivity, used, for example, in the German parliament, the "Bundestag".
This is not 100% comparable, but these 7 mics could point into the same direction.
It's likely that these 7 mics improve the feedback rejection in a PA situation.
And  - what about the "lucky no. 7"?
This is what I was thinking - wired as a line array would give more sensitivity and focus on the speaker with better rejection from the sides.
klaus
« Reply #17 on: January 02, 2018, 07:54:34 PM »
Here is a January 2018 picture of the line-up. New mics, or same as before, but with wind socks?
Considering the recently tightened trade embargo affecting most goods destined for the DRNK: if these mics are new, one wonders how they were legally imported?
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
Jim Williams
Re: 7 Mics for Kim Jong Un - Why? What are they?
« Reply #18 on: January 03, 2018, 11:55:31 AM »
They look fatter than those pencil mics he has used.
Sort of like Kim, the only fat person in all of NK.
hugovanmeijeren
« Reply #19 on: January 08, 2018, 04:46:38 AM »
I'm quite sure those are still the same Beyerdynamic M201 mics (see the typical Beyerdynamic label down the bottom of the mics). This exact type of wind sock is included in the box with every new M201.  ;)
Must have been the same deal: buy 1 get 6 for free. Beyerdynamic order code: M201.DICT-ATOR.starterpack
David Satz
« Reply #20 on: February 05, 2018, 11:31:17 AM »
I am worried for this person who seems to have more microphones than the Dear Leader. Surely that will not go down well.
klaus
« Reply #21 on: February 05, 2018, 05:28:40 PM »
He's betting on Lucky 13!
Klaus Heyne
German Masterworks®
uwe ret
  • Real Full Name: Uwe Sattler
« Reply #22 on: February 06, 2018, 04:45:32 PM »
One dozen (12), not a baker's dozen (13).
klaus
« Reply #23 on: February 06, 2018, 05:55:11 PM »
Don't count on the moderator's ability to count!
Klaus Heyne
German Masterworks®
Mickeyrouse
  • Real Full Name: Mickey Rouse
« Reply #24 on: February 25, 2018, 09:15:26 AM »
TWELVE mics- now I AM impressed. Just imagine the potential for phase issues, especially if they're leading to the same input.
ratite
« Reply #25 on: February 26, 2018, 09:05:35 AM »
Phase issues are products of the decadent bourgeois imperialistic West,they cannot occur in the Democratic People's Republic of Korea!
klaus
« Reply #26 on: March 03, 2018, 07:26:43 PM »
Another leader in front of 7 mics.
In this case, the seven mics connect to seven representatives of the fourth estate, rather than to the leader himself.
Bonus points for identifying the mics!
Klaus Heyne
German Masterworks®
David Satz
« Reply #27 on: March 04, 2018, 04:07:13 PM »
The fifth one from the left is a Schoeps CMIT 5U.
klaus
« Reply #28 on: March 04, 2018, 04:21:32 PM »
Wow! What gives it away?
Klaus Heyne
German Masterworks®
David Satz
« Reply #29 on: March 04, 2018, 04:48:37 PM »
The clear, well-balanced midrange, the smooth frequency response even when sounds arrive from off-axis ... and the bright blue surface finish.
--best regards
Pages: 1 [2] 3  All   Go Up
Page created in 0.076 seconds with 24 queries.
