Author Topic: What causes low frequency bumps in vinyl record playback.  (Read 4226 times)
Thomas W. Bethel
  • Real Full Name: Thomas W. Bethel
  • When only the best will do.
« on: July 18, 2014, 09:14:55 am »
If you look at a vinyl record playback on an oscilloscope set for phase display certain records cause the display to jump vertically. If you filter out any information below 20 Hz by using a high pass filer the oscillations pretty much go away. These bumps seem more noticeable on records that were not made by main stream record companies. I am wondering if this is due to a lathe that has bearing problems or a platter that is not true on the lathe or if these bumps are caused in the plating or pressing of the record? Any help in learning about these would be most welcome.
Thanks in advance!
Thomas W. Bethel
Managing Director
Acoustik Musik, Ltd.
http://www.acoustikmusik.com/
Doing what you love is freedom.
Loving what you do is happiness.
Celebrating 26 years in business in 2021
Greg Reierson
Re: What causes low frequency bumps in vinyl record playback.
« Reply #1 on: July 18, 2014, 10:50:04 am »
All of the above. It would take a close inspection of the vinyl to give clues and even then you may never know the cause. Can you post a sample?
Greg Reierson
Rare Form Mastering
dany500
  • Real Full Name: Dany Brown
« Reply #2 on: October 10, 2014, 05:05:26 pm »
It would take a nearby investigation of the vinyl to give pieces of information and still, after all that you might never know the reason. Can you post a specimen?
We are the pioneers in providing   1z0-051  and SAP  exams with 100% exam pass guarantee.
polypals
  • Real Full Name: Paul Kirchhoff
« Reply #3 on: October 10, 2014, 06:41:12 pm »
The quality of the lathe used to cut the record may certainly be part of the problem.
Do not rule out external influences at the time the record was cut.
On a number of the famous Decca SXL series of classical music low frequency noise can be traced that is caused by London Transport.
The cutting rooms were located in a building close to a bus line in London.
aleeza
  • Real Full Name: asdf qwe
« Reply #4 on: December 30, 2014, 01:27:07 am »
nice and good post
Usman
ericp20
  • Real Full Name: eric paul
« Reply #5 on: May 04, 2015, 08:25:24 pm »
too interesting, very good
