Pages: 1 2 [3] 4   Go Down
Author Topic: U67: Add More Top End?  (Read 32198 times)
Jim Williams
Re: U67: Add More Top End?
« Reply #30 on: February 12, 2015, 10:54:38 AM »
Polystyrene film caps are harder to get these days since all but one of the polystyrene film makers closed shop. The only Amercan brand still making them is Reliable Capacitors in Santa Fe Springs, CA. Their limit is 1000 pf. Some asian caps are still available.
In a pinch a good sub would be a quality polypropylene film and foil cap like the WIMA FKP-2 series. Those come in 1000 volt ratings, 100, 68, 47 and 33 pf are available values.
klaus
« Reply #31 on: February 12, 2015, 01:08:10 PM »
Are you sure that you can use a 160v Styroflex for c17? The Neumann data sheet calls for 500v
Yes, I am sure.
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
soapfoot
  • brad allen williams
« Reply #32 on: February 12, 2015, 01:09:51 PM »
Do you have an opinion on the performance of teflon-dielectric capacitors as a substitute for polystyrene? The obvious downside being cost.
klaus
« Reply #33 on: February 12, 2015, 03:19:18 PM »
Bass Lim's Rel-Cap made me some Teflon film & foil capacitors in the 1mfd range, and, hoping that higher cost would tranlate to higher utility, I did not find them particularly musical or better in resolution or other relevant parameters than tin film & foil, or most intriguing, but very hard to make and find: copper film & foil.
It is also worth repeating what I wrote a while ago: different capacitances demand different materials in the audio chain. For example, I've found that in the capacitance range of 10.000pf or lower nothing beats styrene. But styrene's advantages and sonic attraction diminishes with values above that.
Klaus Heyne
German Masterworks®
Je55
  • Real Full Name: Jess Jackson
« Reply #34 on: February 12, 2015, 09:32:20 PM »
Cheers Jim, I think i'm going to stick with styroflex though. Its just good to know that I can use a lower voltage cap, they are much more readily available in lower voltages than 500v and 630v
Jess
Je55
« Reply #35 on: February 12, 2015, 09:34:27 PM »
Thanks Klaus,
While this is a u67 thread, is there a reason that Neumann didn't use a choke in their psu? I'm leaning to believe a massive part of the u47 ultra smooth sound is due to the chokes in the psu.
I may add one or two in my 67 psu between C4 and R7.
Cheers
Jess
klaus
« Reply #36 on: February 13, 2015, 02:35:58 AM »
Neumann's NG 1 power supplies for U47 did feature chokes (through 1955), then dropped them, and within a couple of years, dropped chokes from all its tube mic power supplies.
I guess, they thought it overkill, and not worth the extra expenses?
Klaus Heyne
German Masterworks®
Brian Campbell
  • Real Full Name: Brian Campbell
« Reply #37 on: March 03, 2018, 12:28:45 PM »
For example the initial U67u 00-00-00S. (Considering that 17 is the highest number for a capacitor in this model, the designation  as C17 may be an indication that is may have been an afterthought...):
I'm curious about the omission of C-17 as shown in the schematic posted by Uwe (U67u).
My understanding is that removing C-17 was a common modification and seems rather controversial.
What effect does this have on the sound?
The other differences in these two schematics are R4, R5  and R19.
Brian Campbell
« Reply #38 on: March 03, 2018, 12:33:26 PM »
here is schematic posted by Uwe
klaus
« Reply #39 on: March 03, 2018, 01:16:52 PM »
Reply #8 goes a bit deeper into the history of the (short lived) omission of C17.
The mic is too bright without C17. Removing C17 does not "restore" full frequency response of capsule or mic amp to a balanced output. The capacitor removes the 9dB boost at 9KHz the capsule would otherwise produce.
Klaus Heyne
German Masterworks®
Brian Campbell
« Reply #40 on: March 04, 2018, 01:39:09 PM »
Given that schematic exits, I wonder if any mics were delivered without C17?
klaus
« Reply #41 on: March 04, 2018, 04:24:13 PM »
I have a client's U67 prototype here- the U60, of which ca. 30 were made before the name was changed to U67. I will check out whether C17 is present in the prototype and report back.
Klaus Heyne
German Masterworks®
AusTex64
  • Real Full Name: Robert Mokry
« Reply #42 on: March 05, 2018, 11:38:35 PM »
RelCap will still make polystyrere caps up to 3uf. http://www.reliablecapacitors.com/audiocap_5.html
I have used these caps in mic preamps with excellent results.
klaus
« Reply #43 on: March 06, 2018, 12:40:42 AM »
... not according to the page you cited.
I commissioned Bass Lim, in charge at Relcap, to roll me a few 1.0 mfd styrenes, so I speak from direct experience:
Not only do styrene caps sound lousy as coupling caps in values above 10.000mfd, they also would be so large at 1.0mdf (the standard in condenser mics) that they would not fit inside a U67.
Tin film & foil is the way to go, and even there, the specialty under-sized cap Relcap makes for me would not fit a U67 unless I reposition the tube and its socket (PITA).
Klaus Heyne
German Masterworks®
Kai
« Reply #44 on: March 06, 2018, 06:31:09 AM »
Wima FKP3 are available in much lower voltages and therefore smaller sizes.
Depending on the purpose these may be a good option, even paralleled for higher capacitance values.
They have the lowest distortion of all available (I built my rig now and can measure down to -154 dB or 0.000002 %).
Selected specimen come down to this figure, even unselected they're not too much worse.
The downside: they are really hard to find if you don't want to buy really large amounts.
Of course, if you want a cap to deliver a special "sound" others might be the choice.
Pages: 1 2 [3] 4   Go Up
Page created in 0.087 seconds with 25 queries.
