Author Topic: Mixing Setup  (Read 1901 times)
Brent Venter
Mixing Setup
« on: January 18, 2012, 03:59:46 am »
Hi Guys,
Excuse the igorance but I need some advice on the most affordable way to build a mixing setup. Effectively I use cubase and will then get raw tracks to mix with. My question is around what is the cheapest way to get 16/24 channels into an analogue console from the PC? The console will then feed the sound system.
This setup is purely to practice mixing in an controlled environment...
Do I get Motu/Presonus Pre's?
Do I get a hard disc recorder/player?
The aim is to be inexpensive so 2nd hand is an option.
Thank You
Shake & Bake
rocksure
  • Real Full Name: Tony Koretz
Re: Mixing Setup
« Reply #1 on: January 18, 2012, 04:51:57 am »
Looking for "cheap" is probably going to get Fletcher the Radar Converter man shaking his head.
If you are going from a computer to a console you don't actually need pre's because the console will have them in it
If you already have tracks recorded in a computer you don't need a hard disc player or recorder because the PC does that job.
What you DO NEED is a device with good D/A converters. You want the best ones you can afford. This could be something from RME perhaps, or better still Lynx Aurora. But they are more expensive. Motu....hmm not so keen on, especially with PC's, Presonus I won't comment on.
Other people here will probably give you different brands and models to think on though.
Royalty-free Music and Sound Effects
http://rocksuresoundz.com
Fletcher
Re: Mixing Setup
« Reply #2 on: January 18, 2012, 07:40:21 am »
If you're looking for good - the Lynx's are good, and relatively inexpensive.  If you're looking for cheap... MOTU, RME, [etc.] are all over eBay and Craigslist -- they were cheap when they were built, and they're even cheaper when the person who originally purchased them decided they needed better and put them on eBay or Craigslist.
The Auroras aren't cheap - they're inexpensive, and there is a difference.
Peace
CN Fletcher
"Recording engineers are an arrogant bunch
If you've spent most of your life with a few thousand dollars worth of musicians in the studio, making a decision every second and a half... and you and  they are going to have to live with it for the rest of your lives, you'll get pretty arrogant too.  It takes a certain amount of balls to do that... something around three"
Malcolm Chisholm
rocksure
Re: Mixing Setup
« Reply #3 on: January 18, 2012, 04:10:16 pm »
Yep that is the kind of answer I expected ^^^. The Auroras are worth the price of admission. One thing about them though is they put out a lot of heat, and need space around them. Not good to jam up against  other gear in a rack.
saint
  • Producer/Engineer/Mixer
Re: Mixing Setup
« Reply #4 on: January 19, 2012, 12:22:37 am »
The Lynx Aurora's do not put out any more heat than the Apogees (or any others I have worked with). It is ALWAYS a good idea to leave at least ONE space in between converters & add a cooling fan (quiet ones) since heat is your ENEMY!! BTW, the Lynx's are in use at Abby Road & Air Studios in London (& they can afford anything!)!
Blue Skies!  Saint
