Author Topic: New 1000 sqft Warehouse Space  (Read 9654 times)
Spindrift
« on: January 24, 2011, 03:41:39 PM »
Would like to set it up for tracking/mixing all in one large room.
Pics and FuzzMeasure tests attached....
Initial impressions?
index.php/fa/16198/0/
Spindrift
Re: New 1000 sqft Warehouse Space
« Reply #1 on: January 24, 2011, 03:43:54 PM »
Considering putting 44 rolls of R30 in all 4 corners for bass trapping, floor to ceiling.
index.php/fa/16199/0/
Spindrift
« Reply #2 on: January 24, 2011, 03:45:22 PM »
It's very LIVE and the verb sound is not bad at all. But I want to be able to vary it with gobos and some permanent ceiling treatments...leaving the floor concrete with some area rugs here/there.  Accurate monitoring though seems to be my problem....that mid-bass bump in the graph is really audible!
index.php/fa/16200/0/
Thomas Jouanjean
« Reply #3 on: January 25, 2011, 12:49:43 PM »
Would make a great live room Smile
If you want to mix as a professional, you'll need a dedicated Control Room.
It's all about what you need to get done and how fast.
Thomas Jouanjean
Pro Audio Partners:
ATC Loudspeakers
FOCAL Professional Speakers
Spindrift
« Reply #4 on: January 25, 2011, 06:23:40 PM »
Thanks Thomas,
I'm quickly coming to realize this is a comprimise no matter which way I slice it. I'm not here permanently so I'm not into investing in a mixroom.
What I'm after is the the value point where it makes some sense to invest some $$$ in treatments to get the most reasonably accurate listening environment for when I do mix in here.
I also know that some great records have been made and mixed outside of the conventional live-room/control-room setup.  Ideal? No. Possible? Yes.
Many thanks,
Keith
Thomas Jouanjean
« Reply #5 on: January 26, 2011, 07:38:12 AM »
Absolutely. It's indeed almost always a question of... Budget.
But it still takes experience to mix in a very large and mostly untreated room. It's not as hard as in a small and mostly untreated room for sure though.
Go the DIY way or pre-made way and lower your RT with broadband traps first. Then once this is down to a good level in terms of the needed "LR" application, see what needs to be done for your "CR" part.
Thomas Jouanjean
Pro Audio Partners:
ATC Loudspeakers
franman
« Reply #6 on: February 03, 2011, 08:44:54 PM »
Ditto.. (FM trying to catch up a bit here.. reading through things... putting 5 cents in...)
Thomas Jouanjean wrote on Wed, 26 January 2011 07:38
fmdesign.com
griffinaudiousa.com
Page created in 0.067 seconds with 20 queries.
