Author Topic: Headphone pet peeve : 1/4" to 1/8" adapters  (Read 7113 times)
Ryan Massey
« on: January 14, 2011, 01:53:26 pm »
Quick rant:
Now that so many clients come in with laptops, Ipods, etc., I can't keep the damn 1/4" to 1/8" threaded adapters on the headphones!  And far too often, they are simply getting lost.  I am seriously considering cutting off all of the TRS plugs from my headphones and hard wiring new ones that are 1/4" only.
Even more annoying (and perplexing) is that the Sony and AT phones use a different thread, so a handful of the new adapters I bought are doing me no good at the moment.  Arrrgghh!
   =www.sharkbitestudios.com=
Jay Kadis
Re: Headphone pet peeve
« Reply #1 on: January 14, 2011, 02:04:26 pm »
Ryan Massey wrote on Fri, 14 January 2011 10:53
Quick rant:
That's what I ended up doing.  (It's fun with the Litz wire Sony uses.)  I tried putting heat-shrink tubing over the adapter but that only slowed them down.
jpaul_bordon
« Reply #2 on: January 14, 2011, 03:13:48 pm »
That Litz wire is a bear, the only way I could get solder to stick to it was to put it under raw flame to burn the coating off.  It sure makes the wire brittle at that point.  Any techniques to solder them?
Jay Kadis
« Reply #3 on: January 14, 2011, 03:27:26 pm »
jpaul_bordon wrote on Fri, 14 January 2011 12:13
I have just burned off the insulation by tinning with solder.  An iron hot enough (~700
ssltech
« Reply #4 on: January 14, 2011, 03:41:15 pm »
I don't believe that it's Litz wire.
It's 'Tinsel wire'.
Litz wire is a piece of cake to solder by comparison!
Keitih
MDM (maxdimario) wrote on Fri, 16 November 2007 21:36
I have the feeling that I have more experience in my little finger than you do in your whole body about audio electronics..
Jay Kadis
« Reply #5 on: January 14, 2011, 03:57:19 pm »
ssltech wrote on Fri, 14 January 2011 12:41
It's 'Tinsel wire'.
Keith
Ah, so it is.  At least they didn't use knob-and-tube!
YZ
« Reply #6 on: January 14, 2011, 04:34:00 pm »
Superglue. (for the 'built-in' adapters)
And bright-colored 1/4"-to-1/8" adapters; keep a quantity in a locked drawer and make only two or three visible per session.
IDK about the USA, but here they can be found in red.
If you can't get them in color, get the black ones and paint them pink with nail polish.
regards,
YZ
marcel
« Reply #7 on: January 14, 2011, 04:37:50 pm »
Loctite?
EDIT:  YZ beat me to it.
Best, Marcel
MagnetoSound
« Reply #8 on: January 14, 2011, 06:03:20 pm »
Yes, tinsel cable is not meant to be soldered.
Crimp tags in all those PO-gauge patch leads, last forever.
Music can make me get right up out of my chair and start dancing or it can get me so pumped up I have to walk around the block.
It can also knock me back and make me sit there and cry like a little baby. This shit is as powerful as any drug!!!
- Larry DeVivo
arconaut
« Reply #9 on: January 14, 2011, 10:19:17 pm »
Yup, I replace all the ends with 1/4" on ours. We keep a few pair of headphones with the mini jack, just to have. For iPod, etc, playback, I have mini to TRS 1/4" cables that feed into a panelmounted TRS jack connected to a Matchbox which is wired to an External 2-Track input on the desk.
Those little adapters can be shockingly expensive.
You Are Number Six
Ryan Massey
« Reply #10 on: January 15, 2011, 12:17:37 am »
marcel wrote on Fri, 14 January 2011 13:37
Loctite?
Loctite! Brilliant!
I'll give that a shot first before I pull out the iron.  I don't think the AT phones suffer from the lousy tinsel wire, so I'll replace those before bothering with the Sony's.  Thanks!
TB-AV
Re: Headphone pet peeve : 1/4" to 1/8" adapters
« Reply #11 on: January 15, 2011, 02:19:02 pm »
Don't forget that most locktite is a wicking sealer. Meaning it will try to make it's way to any nooks and crannies it can. It might end up insulating the audio contacts over time.
marcel
« Reply #12 on: January 16, 2011, 01:04:07 am »
TB-AV wrote on Sat, 15 January 2011 11:19
I think Loctite is basically CA glue, like Krazy glue.  Once it sets, it becomes very hard and should not move or migrate.  If you put a  very small drop on the top of the adaptor (where it meets the body of the jack) with the adaptor firmly screwed in place, you could probably 'lock' it without disturbing any electrical paths.
Krazy glue might work just as well, and be cheaper.
Best, Marcel
arconaut
« Reply #13 on: January 16, 2011, 09:52:21 am »
I am dubious but curious about this:
http://www.thinkgeek.com/interests/giftsunder10/b70c/
You Are Number Six
johnR
« Reply #14 on: January 16, 2011, 04:56:13 pm »
marcel wrote on Sun, 16 January 2011 06:04
Loctite is anaerobic methacrylate resin. It hardens in the absence of air. Cyanoacrylate glue (superglue) hardens in response to the moisture content in air. Two different adhesives.
