Author Topic: Choosing Sidechain frequencies for the OCL-2  (Read 4335 times)
Alécio Costa - Brazil
« on: June 05, 2010, 05:50:57 pm »
Hi, folks
Which are the most used side chain frequencies you guys select for the Pendulum OCL2?
I intend to build a small box, so it is time to thing about frequency selection...
I was thinking of :
1 - 40
2 - 60
3 - 90
4 - 120
5 - 150
There was a thread at GS where something like 320 was also chosen. Seems a bit high, right?
Thanks
Alécio Costa Studio
High-end Mastering, Music Production
http://www.aleciocosta.com
Listen to my album at:
http://www.audiostreet.net/aleciocosta
MySpace:
http://www.myspace.com/aleciocostamasterizacao
Andrew Hamilton
Re: Choosing Sidechain frequencies for the OCL-2
« Reply #1 on: June 07, 2010, 03:58:43 am »
Bom dia, Al
www.serifsound.com
premastering for CD and DVD-A.  Featuring FTP load in and delivery as well as analog tape transfers.
« Reply #2 on: June 08, 2010, 01:20:05 am »
Thanks, Andrew!
BTW I used to be an electrical engineeer
LOL
Alécio Costa Studio
MySpace:
« Reply #3 on: June 08, 2010, 01:24:20 am »
p.s: If you come to Brazil, drop me a call and I may take you to visit some of the 43 beaches we have here!
Alécio Costa Studio
MySpace:
Andrew Hamilton
« Reply #4 on: June 08, 2010, 11:30:08 am »
I'll let you know if I make it there.  Thanks.  By the way, I meant to say that the frequency column in my list contained the _non_-integers, and the capacitance column, the integers...
Memristically, yours,
Andrew
www.serifsound.com
« Reply #5 on: June 10, 2010, 09:32:25 am »
Cool
Let us Keep In contaqct!
Alécio Costa Studio
MySpace:
The Buzz
« Reply #6 on: June 13, 2010, 02:22:25 am »
From listening experience, changing a HPF in the side chain of a compressor has to be quite radical to notice any real change.  If the filter is only a 6dB slope, then yes, starting roll off at 300Hz is not as silly as it sounds.  The thread you mention might have been about the Atlas compressor I designed, which has such a filter in the sidechain.  But if the filter has a steeper slope then lower cutoff freq's will work.
Tim
« Reply #7 on: June 16, 2010, 12:23:20 am »
Interesting, Tim.
Alécio Costa Studio
MySpace:
bblackwood
« Reply #8 on: June 16, 2010, 12:45:28 am »
Honestly, while one would think the lower freqs were too subtle, I find myself using all five selections on mine with some regularity. The one thing I'll likely do is add a '2x' switch to the side to make higher freqs available.
But yah, I find even the lower freqs useful.
http://www.euphonicmasters.com/misc/OCL2_SC_HPF.JPG
Brad Blackwood
euphonic masters
Viitalahde
« Reply #9 on: June 16, 2010, 06:12:25 am »
Yeah, my Knif compressor has SC cutoffs at 30, 50, 70, 100, 150 and I often find myself using 50 and 70, sometimes the upper ones.
Brad: I think that 2x switch could be done by putting a toggle switch at the output, shunting a resistor equal to the input Z of the OCL2 to ground. 10k?
Jaakko Viitalähde
http://www.virtalahde.com
bblackwood
« Reply #10 on: June 16, 2010, 08:51:16 am »
Viitalahde wrote on Wed, 16 June 2010 05:12
Yah, that's what I'm thinking. Should be a simple 'mod', and making some even higher freqs available can't hurt.
Brad Blackwood
euphonic masters
« Reply #11 on: June 17, 2010, 01:30:58 am »
Brad, are your filters 6dB/octave, 12...?
Have you felt the need to go  into the low mid area with the side chain frequencies? (300 for example)
Alécio Costa Studio
MySpace:
bblackwood
« Reply #12 on: June 17, 2010, 08:31:54 am »
Al
Brad Blackwood
euphonic masters
dcollins
« Reply #13 on: June 17, 2010, 01:50:28 pm »
I guess it's worth mentioning that the OCL-2 has a 15Hz S/C filter internally so any external rolloffs are in addition to this.
DC
Andrew Hamilton
« Reply #14 on: June 18, 2010, 06:26:55 am »
dcollins wrote on Thu, 17 June 2010 13:50
DC
Wouldn't that mean that the quality of the s/c-hp filter becomes 2nd order (when using the Blackwood mod - or even swappable TRS connectors with caps soldered on, for those s/c inserts)?   If so, then perhaps the Buzz would object less to the notion of the efficacy of selectable low end corner frequencies for the side chain.
Andrew
www.serifsound.com
