Author Topic: To the vinyl cutters - clipped waveform  (Read 25218 times)
Ben F
« on: April 15, 2010, 08:13:24 PM »
Sometimes on 12" EPs my hands are tied. 1 track done elsewhere and clipped, I can't do much about it. The others I do as normal with only a small amount of limiting and headroom. It must be quite common these days with the amount of DIY clipping.
If you receive a file that has been very clipped instead of limited, how does this affect the cutting process?
TotalSonic
Re: To the vinyl cutters - clipped waveform
« Reply #1 on: April 15, 2010, 10:27:15 PM »
Generally the thing that happens is it gets cut at a quieter level than it would otherwise need to be if it was unclipped if you want to avoid distortion on playback.  How much dB difference this ends up being is totally dependent on the specific program and the cutting level being aimed for.  Often the side length is dictating cutting level first - so if it's a long side this might not if fact create an issue at all.
i.e. The pre-masters I got from Bob Ludwig when I cut the Foo Fighters "In Your Honor" 4LP set were definitely clipped throughout - but because the cutting level was kept around +2dBVU at the peaks, at least 20% of the inner diameters were not used, and it was cut at 45rpm this ended up being a clean transfer (Bob's excellent eq job helped as well).
If it's a 12" DJ oriented where the client is wanting maximum possible level this can definitely effect things though.  i.e. I cut masters for a Japanese special edition reissue of Wayne Wonder "No Letting Go" 12" single which had a tenor vocal that was heavily processed and then over all levels clipped on the pre-master - and there simply wasn't any way to get it to playback cleanly at the +4dBVU (or more if I could get it) levels being requested.  The client thought the problem was because the cut I had done was on DMM - and had it recut on lacquer - only to have the test pressings for these come out actually sounding worst.  He ended up coming back to me to recut a 3rd time - sourcing a German version of the pre-master that was a tiny bit less clipped, we did some small upper midrange cuts, and turned down the level for the whole side - and he ended up reluctantly being ok with this compromise.
So - clipped material can indeed be cut - but in my experience you can get better sound (and level) for the vinyl if it's not clipped.
Best regards,
Steve Berson
Ben F
« Reply #2 on: April 15, 2010, 11:09:01 PM »
Thanks Steve.
It's a tough one as you know some tracks only really sound good with a bit of clipping over any other method, and there is always the super quiet (or loud)one on an EP that I have to deal with.
Is there any difference cutting do DMM over the traditional lacquer? Or do the standard headroom and not too much out of phase bass technical aspects apply?
TotalSonic
« Reply #3 on: April 15, 2010, 11:38:52 PM »
Ben F wrote on Thu, 15 April 2010 23:09
Thanks Steve.
I'd say your absolute best bet if there are any questions regarding the pre-master is to have the client get a reference acetate (aka "dub plate") made first for there approval prior to taking on the expense of lacquers, stampers and tests being made.  That way if there's any issues they can be addressed first without having to spend more money and time than otherwise necessary.
Main thing is not to over think things too much - make the pre-master sound good to you, keep it on the "warm" side if you can, and it will likely translate well to vinyl.
The same issues apply.  DMM in general has less pre-echo, greater high frequency definition - but tighter depth tolerances than lacquer - and there's definitely some folks who prefer lacquer over DMM -  but when I was cutting (can't believe this was 5 years ago already) I never found a program that I couldn't get sounding to the client's satisfaction with it.
fwiw - the Sharon Jones & The Dap-Kings latest LP that just got released was cut to DMM at Abbey Road from 24bit/88.2kHz premasters that I made - and I think it sounds pretty darn nice!
Best regards,
Steve Berson
Gold
« Reply #4 on: April 16, 2010, 12:34:37 AM »
I haven't found clipping in and of itself to be much of a problem. Audible distortion is a problem no matter what the cause.
Paul Gold
www.saltmastering.com
On the silk road, looking for uranium.
Macc
« Reply #5 on: April 16, 2010, 07:13:01 AM »
TotalSonic wrote on Fri, 16 April 2010 04:38
OT but huge Daptone fan here - waiting for my copy of the CD to arrive. Did you do that as well, could I ask?
Bob Macciochi
www.scmastering.com
TotalSonic
« Reply #6 on: April 16, 2010, 12:26:40 PM »
Macc wrote on Fri, 16 April 2010 07:13
Yup - I did all the mastering for "I Learned The Hard Way" except for the transfer to DMM.  It was a really fun album to work on.
Anyway - I've mastered most of the Daptone releases from the past 3 years with the exception of Naomi Shelton (mastered by Paul Gold) and "100 Days, 100 Nights" (mastered by Scott Hull), and some of the 45's (for which I've pre-mastered a few, but most were by done by either George Ingram at Nashville Record Productions or Paul Gold).  The earlier releases were all mastered by Don Grossinger.
Best regards,
Steve Berson
bigaudioblowhard
« Reply #7 on: April 16, 2010, 03:48:56 PM »
TotalSonic wrote on Thu, 15 April 2010 21:38
Best regards,
Steve Berson
Which album is that Steve?
I've got SJ & TDK "100 Days, 100 Nights" here, with Scott Hull listed as ME. Its cut pretty low. Sounds good to me.
bab
TotalSonic
« Reply #8 on: April 16, 2010, 04:10:52 PM »
bigaudioblowhard wrote on Fri, 16 April 2010 15:48
Best regards,
Steve Berson
"I Learned The Hard Way" - released 4/6/2010 -
http://www.sharonjonesandthedapkings.com
- just debuted at #15 on the Billboard album charts.
I like what Scott did on that one - I don't think he used any digital limiting at all and just kept the mids forward to still give it some presence.   There was a little bit of limiting used on some of the tracks for this new one (at the very most a dB of gain reduction - and a few don't have any)  but I'd say it's been kept way more dynamic than the vast majority of releases these days.
Best regards,
Steve Berson
Fenris Wulf
« Reply #9 on: April 19, 2010, 10:34:55 PM »
I had to pre-master some very badly recorded material for vinyl. It had severe clipping from the ADC. The waveform literally looked like a brick and I was worried about what it might do to the cutter amp. I used EQ and a multi-band expander on it to try to restore it to some semblance of a normal waveform, and left a few dB of extra headroom so the RMS was at a normal level.
When some ADC's are clipped, they produce a burst of energy right at the Nyquist frequency. It's a good idea to cut it with a notch filter or LPF.
RESIST THE CYBERNETIC OVERLORDS
KDVS Studio A
jason goz
« Reply #10 on: April 20, 2010, 12:05:20 PM »
Fenris Wulf wrote on Tue, 20 April 2010 03:34
Did you do any test cuts before deciding on this coarse of action?
TotalSonic
« Reply #11 on: April 20, 2010, 03:04:31 PM »
Jason Goz wrote on Tue, 20 April 2010 12:05
Good question -
With pre-mastering for vinyl it's so easy to over think things as to what might be a problem or not -  the only true way to know is a test cut.  Sometimes what you think might cause a problem is a non-issue, and sometimes when you think there shouldn't be a problem one rears it's ugly head.
Beyond simply to make things sound good in general 2-bus processing with the goal for making the side translate to vinyl should be left in the hands of the engineer doing the actual transfer.  De-essing the specific places that need it when mixing - and not clipping when pre-mastering - can certainly help make the cutting go smoother though.
Best regards,
Steve Berson
Gold
« Reply #12 on: April 20, 2010, 08:10:30 PM »
If it's the one I recently cut from KVDS it cut without incident.
Paul Gold
Fenris Wulf
« Reply #13 on: April 21, 2010, 08:36:51 PM »
Was it "Art Lessing and the Flower Vato"? I haven't heard the vinyl yet, I'll have to see if it came in.
KDVS runs a micro-budget record label, and I sometimes do fixes on badly recorded stuff that originated on cassette, Soundblaster, MP3, or worse. I'm not a real ME, I just try to make it not physically painful to listen to. The orignial waveform was so badly clipped that it seriously looked like full-scale pink noise. Very Happy
KDVS Studio A
Gold
« Reply #14 on: April 21, 2010, 08:43:12 PM »
Fenris Wulf wrote on Wed, 21 April 2010 20:36
Yep, that's the one. I have just cut acetates but John was happy with them. I am waiting to be escorted through the UC maze before I cut lacquers.
Paul Gold
Page created in 0.073 seconds with 21 queries.
