Author Topic: DC Choke 1.5 H - Acoustic 370  (Read 6272 times)
Deuce 225
« on: March 22, 2010, 10:31:43 PM »
One of the chokes on my Acoustic 370 Bass Heads EQ's is dead and I can't seem to find a replacement.  Harvey or Jim Williams any ideas where I might score one?
Thanks,
Tim Cochranindex.php/fa/14481/0/
Best,
Tim Cochran
Galil
Re: DC Choke 1.5 H - Acoustic 370
« Reply #1 on: March 22, 2010, 11:37:21 PM »
Judging from the size of the inductor, that is hopefully a 1.5 millihenry inductor. A henry is a very large amount of inductance, far more than is typically used in an audio circuit. If you pull a good inductor out of the circuit, you could measure it and determine the value with a LCR bridge or multimeter with a LCR function.
Are you certain that the inductor has failed?  Usually they are not the problem in an audio circuit; I've seen many more transistors, diodes and capacitors go than inductors.  It might be worth it to re-solder the inductor back in and see if it is a cold solder joint under the inductor.
If you are looking for electronic parts, both
http://www.digikey.com/
and
http://www.mouser.com/
are good to know about and should have some lines of inductors which can electronically replace your part (physical fit may be an issue).
Harvey was involved with Acoustic in the 1970s and might have some additional information on this.
Galil
Deuce 225
« Reply #2 on: March 23, 2010, 06:13:39 AM »
Galil...Are you certain that the inductor has failed?  Usually they are not the problem in an audio circuit; I've seen many more transistors, diodes and capacitors go than inductors.  It might be worth it to re-solder the inductor back in and see if it is a cold solder joint under the inductor.
[url
http://www.digikey.com/[/url]
and
Galil
Thanks, yes we are sure the choke has failed, we have moved it to a different location and the problem moves with it.  I have searched both Mouser and Digikey for a replacement part, unless I have overlooked it, they do not have one.  FYI - the reason I posted on Harvey's forum is because I knew of his background with at Acoustic.
Thanks again,
Tim Cochran
Best,
Tim Cochran
hargerst
« Reply #3 on: March 23, 2010, 11:10:25 AM »
Tim,  there's a thread about these inductors over at the Acoustic forum:
http://unofficialacousticcontrolcorpmessageboard.yuku.com/to pic/2565
There are a few possible sources listed there
Harvey "Is that the right note?" Gerst
Indian Trail Recording Studio
Michael Brebes
« Reply #4 on: March 23, 2010, 03:39:23 PM »
Cinemag would probably build you one:
cinemag.biz
Deuce 225
« Reply #5 on: March 23, 2010, 07:05:07 PM »
Thanks for the suggestions, we are following up on several leads and ideas.
Best,
Tim
Best,
Tim Cochran
Page created in 0.283 seconds with 19 queries.
