Author Topic: Could not complete Bounce in PT  (Read 2398 times)
Jonah A. Kort
« on: January 14, 2009, 06:11:26 PM »
I'm getting the Stop sign and the text "Could not complete the Bounce to Disk "FF_AudioProperty.cpp Line33"
Please.  I need to bounce this mix asap...
Thanks
grantis
Re: Could not complete Bounce in PT
« Reply #1 on: January 14, 2009, 06:18:05 PM »
Trash the databases and see what happens...or...Bounce to another drive...or...up your hardware buffer size...or...up the DAE buffer...
Grant Craig
Nuovo Music (Me)
Skiddco Music (Where I work)
Work History (Well, some of it anyway)
Jonah A. Kort
« Reply #2 on: January 14, 2009, 06:30:02 PM »
DAE is all the way up
Hardware buffer is all the way up
Trashed the databases
I can't bounce to my external...not a playback drive...
grantis
« Reply #3 on: January 14, 2009, 07:10:13 PM »
Go to workspace and change the external from "T" to "R"
Grant Craig
Nuovo Music (Me)
j.hall
« Reply #4 on: January 14, 2009, 09:37:54 PM »
when you ditch your databases you have to empty the trash and reboot your machine.
compasspnt
« Reply #5 on: January 14, 2009, 11:13:08 PM »
Change the length of what you are trying to bounce...shorten or lengthen by maybe a second, and try again.
thedoc
« Reply #6 on: January 14, 2009, 11:25:57 PM »
index.php/fa/10928/0/
Doc
Derek DiFilippo
« Reply #7 on: January 15, 2009, 12:39:36 AM »
Hey Jonah,
Try taking the DAE down from Level 8 to Level 2 (the default).
That's worked for me in the past.  A bit counter-intuitive.  Terry's suggestion to change the bounce length also worked for me, but not as consistently as leaving the DAE at Level 2.
recall
« Reply #8 on: January 15, 2009, 09:28:02 AM »
If you have a spare AUX and Audio track, just send the mix to the bus and route it to the spare audio track.  I had loads of problems a couple of years back with the bounce handler.  PT7.4 is fine bouncing for me now, but I still use the Record to disk method as it is totally reliable.
Good luck
Iwan
Iwan Morgan
Producer/Engineer
www.westwalesgothic.co.uk
j.hall
« Reply #9 on: January 15, 2009, 12:15:22 PM »
oddly enough, PT totally crashed on me today.  first time in a very , very long time.
jonah, you got weird PT mojo up there?  stop sending it down here..........
Jonah A. Kort
« Reply #10 on: January 16, 2009, 07:19:39 AM »
Derek going to level Two did the trick...
J. I was about to send you the song I was trying to bounce but
maybe I shouldn't...punk rock bands with bagpipes may not be good
PT...
Page created in 0.099 seconds with 20 queries.
