Microtech Gefell PVC M7 are easily recognized by two unique features.
One, the center screw has a 1.0mm thread, rather than the 1.2 mm thread which was and is standard on all Neumann capsule lead-out screws. Though you cannot see the thread when the screw is fastened, its smaller head size gives it away. (someone else can supply some nice JPGs to illustrate!)
Second, Gefell used, and still uses, Neumann's M7's pre-World War II ridge configuration:
Looking at the rim of the capsule, you will recognize several concentric ridges and troughs that are visible under the stretched diaphragm, towards the edge of the capsule, where the diaphragm is glued to the backplate. Neumann used three ridges, Gefell two.
However, after the war, Neumann used many different configurations as to width of ridges and troughs, which allow for M7 period classification, yet there were always three ridges, until the introduction of the K47, which had only one.
When discussing visual identifiers, please keep in mind that Gefell's backplate configuration for its current-day Gefell M7 with Mylar
