Author Topic: TAB V78 Settings Chart  (Read 863 times)
Stranger 55
« on: January 05, 2009, 09:50:41 PM »
Hey All,
I was talking with Terry about the V78 when adopting CS-1 #63.  he mentioned that Oliver had sent him a chart showing how to best set the V78 for different kinds of microphones and that maybe that chart could be posted on the forum.
i know you guys are crazy busy with the CS-1, but is it possible to post the chart?
thanks and happy new year!
Tom
Tom Brayton
compasspnt
Re: TAB V78 Settings Chart
« Reply #1 on: January 05, 2009, 11:26:26 PM »
Hey Tom.
I will look for that tomorrow, and try to post it.
T
EDIT:
Ha, found it on my laptop at home right away.
Here is what Oliver emailed me back about three years ago when I got mine:
Hello Terry,
Here is a chart of the input sensitivity vs. clipping with reference to
20/1k/20k Hz at 0dB gain
+6dB max input 23dBu (10V) same as 0dB
0dB max input 17dBu (5V) mix buss, two bus, etc.
-10dB max input 12dBu (3V) modern condensers high output like TLM, etc.
-20dB max input 6.6dBu (1.643V) condensers like U47, M49, KM5x, KM8x, etc. and similar
-40dB max input 0dBu (0.775V) modern ribbons and standard (like SM57/58) dynamics; condensers like C12(a), C60, etc.
-40 dB max input -8.5dBu (0.2945V) vintage ribbons and low output dynamics
Those setting above are just suggestions with reference to 0dB-0.775V, the V78M was designed with soundforming (over and underloading of the input) in mind, so whatever sounds best is what you should use.
output clipping is unloaded/10k load min. +12dBu and loaded with 600 Ohm +11dBu.
So in any case as long you do not try to use it on a +12dB (old IRT specs) system you should be fine, and any setting +4/8dB, etc.
Best regards,
Oliver
Stranger 55
« Reply #2 on: January 06, 2009, 03:29:39 PM »
Thanks Terry!
Tom Brayton
Page created in 0.097 seconds with 19 queries.
