Author Topic: "Hens' Teeth" API 560s.  (Read 11097 times)
rickymix
« on: September 29, 2008, 01:09:44 am »
Hi y'all!  First time posting here, but some of you may know me from the newsgroup formerly known as rec.audio.pro.  Well, it's still called "r.a.p." but it just isn't the community it once was in its glory years.  Fletcher suggested that I drop by here and check out this forum, and yeah, this looks pretty cool!  Nice.
    So Fletcher and I were trying to figure out the current value of my API EQs, which I love but rarely use these days since I no longer have a tracking room.  I have a pair each of original 550s, 550As, and 560s.
    The 560s are the vintage "Hen's Teeth" version with the original long-throw faders and 2520.  They're in great condition, which as you probably know is what makes them rare, since most vintage 560s have been destroyed over the years by people spraying them with Deoxit or Cramilon, etc, which kills the faders.  Those original faders haven't been manufactured for decades, so all the subsequent API 560s; As, Bs, Reissues, etc, have short-throw faders which have less subtlety.
    I can't find any info online regarding the current value of any vintage API EQs.  All the stuff on eBay, etc seems to be the new reissues.  Do y'all have any anecdotal info regarding the realistic value of these, or suggestions of where to look for info?  Yeah right, you'll be happy to take them off my hands for $10.00 a piece!  :>)  No, but seriously folks.....
    Thanks for sharing you're expertise and time!
    Cheers,  Rick Novak.
Hank Alrich
Re: "Hens' Teeth" API 560s.
« Reply #1 on: September 29, 2008, 01:12:46 am »
Hey, Ricky, good to see you here!
I'll give ya ten bucks for 'em.
Andres Gonzalez
« Reply #2 on: September 29, 2008, 08:24:12 am »
About 7 years ago, I purchased a couple of original 550A in excellent condition for $1100 each.
At least this is a data point for you for the 550As. I have never purchased an original 560 (I have a couple of the reissues 560s).
-Andres
Andres Gonzalez
« Reply #3 on: September 29, 2008, 08:32:24 am »
rickymix wrote on Mon, 29 September 2008 01:09
.... Those original faders haven't been manufactured for decades, so all the subsequent API 560s; As, Bs, Reissues, etc, have short-throw faders which have less subtlety.
How can a 500-series module have "long-throw" faders? Is the physical size the same? and then the resistance range of the fader wider?  When I hear "long-throw" I assume that refers to the physical/travel range of the fader.
-Andres
Haolemon
« Reply #4 on: September 29, 2008, 07:33:56 pm »
The faders adjust left to right.
Andres Gonzalez
« Reply #5 on: September 29, 2008, 08:13:58 pm »
Haolemon wrote on Mon, 29 September 2008 19:33
Yes, that is my point. The 500-series modules are only 2 inches wide so I have a hard time thinking of them as being able to be "long throw."  So to have a 560 "long throw" version with less than 2 inches left-to-right just seems odd to me. That is why I am asking if the "long throw" version is the same physically as the re-issues--the difference being the resistance range of the actual fader.
-Andres
rickymix
« Reply #6 on: September 29, 2008, 10:35:12 pm »
Hiya again Hankster!  Twice in the same day after a half year off!   :>)
    Andres, the 10 little faders which move left to right are the same size on all of the 560 models.  If you push the faders to the extreme left or right they all sound the same.  But on the original "Hens' Teeth" version, the middle area near the center detent is "longer throw", meaning that you have to move the fader further left or right to cut or boost the audio by the same number of dbs.  My initial reaction was the same as most people's; "What's the big deal with that?  So what?"  The reason it's important, and why these old EQs are so desired is this:
    The vast majority of the time you DON'T push those faders to their extreme.  Usually you make subtle "S" curves with them, and the majority of those 10 faders are very close to their center detent.  Certainly closer to the center than to the extremes usually.  Multiply that times ten faders, and it's simply much easier to sculpt good sounds with the old long-throw version.
    Hope that explains it.  Let me know if not.
    Cheers,  Rick.
Andres Gonzalez
« Reply #7 on: September 29, 2008, 11:12:30 pm »
Yes, thank you for the explanation--that helps alot.
I did not think the fader was physically different--it wouldn't be a 560 without 10 horizontal faders--I figured it was just a different taper on the pot. But I have never seen a "Hens' Teeth" 560 and I associate "long throw" faders with consoles with long faders.
Thanks again for the clarification.
-Andres
Bryson
« Reply #8 on: September 30, 2008, 07:51:21 am »
Andres Gonzalez wrote on Mon, 29 September 2008 20:12
As do I.
Hank Alrich
« Reply #9 on: September 30, 2008, 11:03:02 am »
Bryson wrote on Tue, 30 September 2008 04:51
As do I.
So imagine laying on a tall couch and looking at the console sideways!
rickymix
« Reply #10 on: September 30, 2008, 05:49:36 pm »
Actually you're right Andres, it's more a matter of "taper" than of "throw".  I've just always heard the old API 560 faders called "long throw".  What would be the correct way to describe them using the term, "taper"?  "Long taper"?
    The issue with any API 560 faders is that they shouldn't be sprayed with ANYTHING; Deoxit, Cramilon, WD40, etc.  It destroys them.  And then they can only be replaced with the newer "short taper" faders.  Which is why old 560s in good condition are "rarer than hens' teeth".   :>)    They used to be the most expensive of all the API EQs.
    I've got a pair in good condition and have no idea of how to value them now.  I remember thinking the prices of API EQs were silly when they were valued at $300 each when I bought the Record Plant API desk from Stevie Wonder in 1986!   :>)    I kept a pair each of 550s, 550As, and these "Hens' Teeth" 560s when I eventually sold the desk.  But I rarely use them now in this digital world, especially since I no longer own a drum tracking room.
    Any advice on how to go about selling these EQs?  Where and for how much?
    Thanks as always,
    Rick Novak.
Silvertone
« Reply #11 on: October 01, 2008, 07:58:18 am »
Sounds like what they use on the original Electrodyne 712 switches or the later Sphere 900 series.
If so Digitran still sell the set for 1800.00 each!!!
Caig actually makes a conductive plastic spray that works extremely well with these type "faders" or switches. I've had "totally stuck ones" that move like they are brand new now.
Do they look like these? ...
index.php/fa/10045/0/
Larry DeVivo
Silvertone Mastering, Inc.
PO Box 4582
Saratoga Springs, NY 12866
www.silvertonemastering.com
To see some of our work please click on any of the visual trailer montages located at... http://robertetoll.com/  (all music and sound effects were mastered by Silvertone Mastering).
tom eaton
« Reply #12 on: October 01, 2008, 08:02:58 am »
Sounds like you're describing the difference between log taper and linear taper.  Long throw and short throw does refer to the distance the fader travels, not the way the resistance varies across the throw.
tom
rickymix
« Reply #13 on: October 02, 2008, 04:07:11 am »
"Log taper", "long fader"...   Hmmm, maybe I, or someone else, simply heard it wrong back in yore, and I've been saying it wrong all these years?  Could be.
I'm sure you're correct; the old 560 faders should be called Log Taper faders and the new ones are Linear Taper.
As for the cleaning spray; I have a can of "CAIG DeoxIT D5" which I've been warned not to use on my 560s under penalty of being beaten to death with a wet noodle!  DeoxIT is certainly a miracle substance which I used to use regularly and generously on practically everything else, 550As, patchbays, etc, but never the 560 faders.  The Electrodyne/Sphere faders are very different, BTW.  They're stepped, aren't they?  Lovely desk, BTW!
Cheers,  Rick.
Silvertone
« Reply #14 on: October 02, 2008, 07:29:03 am »
rickymix wrote on Thu, 02 October 2008 03:07
Cheers,  Rick.
Yes Rick, you are correct, they are stepped in 2dB increments. Thanks for the compliment on the console she's been a labor of love for the past few years. I just picked up two of the CA 702 compressors for her.
Caig does make a conductive plastic spray. I use it all the time (for over 20 years now). I'll get the name off the bottle later today. I highly recommend it. For sticky metal pots and such I use Miller-Stevenson, I've found it to be better than the Caig and leaves no residue like Caig can (I'm talking for cleaning not lubing).
Larry DeVivo
PO Box 4582
