MDM, wrote on Mon, 12 May 2008 04:44 |
if we focus on impulse response instead of bandwidth of steady-state signals, harmonics etc..
how does settling time fit into all of this, and would an opamp system with high slew rate also have a good settling time?
Slew rate is how fast does the amplifier go when it can't keep up with the input signal (clipping in rate of change). Settling time is, how quickly does it regain control of it's output again after the step input is reached. One can imagine different strategies for how the amp works in this overdriven condition. One where the slew rate is modulated by the degree of overdrive, seems like it would recover more gracefully than one that just toggles to some maximum slew rate during the slightest overload, while the one with the full on slew may get you there sooner.
To properly evaluate settling time, you really need to specify the degree of overdrive. This is more a consideration for data acquisition design involving sample and hold requirements and not for band limited audio.
IMO a well crafted audio path will be faster than the fastest signal it will encounter. Out of band information, needs to be harmlessly band limited early in the audio path and in such a way that no audible artifacts are generated. This well designed circuit does not have a slew rate, but can be characterized adequately by an impulse rise time, and a full output bandwidth. Properly executed a large and small step impulse will have exactly the same shape (rise time). If allowed to slew limit the large and small step impulse will be reproduced quite differently
