Author Topic: Tips for Backup Vocals  (Read 7865 times)
raw-tracks
Re: Tips for Backup Vocals
« Reply #15 on: April 27, 2004, 12:38:21 pm »
When balancing BGV's, I like to monitor at very low volumes, almost inaudible. I find this allows you to get a good balance.
Eric
Practice Your Mixing Skills
www.Raw-Tracks.com
www.Mad-Host.com
groove guru
« Reply #16 on: April 27, 2004, 09:21:51 pm »
I usually record several bgv tracks, pan and compress them, then send them to their own bus where I'll eq and add fx.  I will normally pull out a few db at around 3k to soften them up a bit so that they don't step on the lead.
John Ivan
« Reply #17 on: April 28, 2004, 09:31:43 am »
raw-tracks wrote on Tue, 27 April 2004 11:38
Yeah:
I too find myself listening to stuff very quietly. Not just BGV but, I've been listening at a lower level in general for the last couple years. My last room was not so great {in the bottom} and I found it helped keep standing waves from being so loud. My friend Scott at Frontier Recording likes to listen quietly also, and we did a-lot of work together and he got me hooked..
"Transformation is no easy trick: It's what art promises and usually doesn't deliver." Garrison Keillor
groove guru
« Reply #18 on: April 28, 2004, 05:13:30 pm »
I find myself monitoring at a low level most of the time now also.  When I do crank the mains(for any extended peiod) I usually listen from outside the room.
meverylame
« Reply #19 on: April 29, 2004, 03:20:26 am »
COMPRESSION COMPRESSION COMPRESSION COMPRESSION COMPRESSION COMPRESSION COMPRESSION COMPRESSION COMPRESSION COMPRESSION!!!
Cheers!
Jason Kingsland
http://www.jasonruinsrecords.com
