Author Topic: Neumann M269c.  (Read 17408 times)
Fibes
Neumann M269c.
« on: April 21, 2004, 05:35:43 pm »
First of all i would like to welcome Klaus and his knowledge to this forum, i hope to exploit it for all it's worth. It's an honor to be a moderator with a crew like y'all.
The M269c- My absolute favorite condenser mic, the german broadcast version of the U67. Absolute magic in my opinion.
I have a problem--- My Tuchel connector is loose and the mic becomes intermittent when hung upside down. Is this an easy fix? Who should i send it to get repaired and tweaked? Klaus?
I fear that this will require a retooling, please tell me it's an inexpensive fix, it's been a week of gear meltdowns...
Thanks,
Fibes
"You can like it, or not like it."
The Studio
  http://phobos.apple.com/WebObjects/MZStore.woa/wa/viewArtist ?id=155759887
http://cdbaby.com/cd/superhorse
http://cdbaby.com/cd/superhorse2
Fletcher
Re: Neumann M269c.
« Reply #1 on: April 21, 2004, 08:11:16 pm »
I'm not Klaus... but I'm going to take a whack at it.  If I'm not mistaken, the M-269c employed the same connector on the microphone as the U-67.  That part was available from Neumann/USA last time I checked [which was a while ago], as are the cable mount connectors for U-67's [the stand mount connector housing is rather difficult to find, but the inside is the same... IIRC].
CN Fletcher
"Recording engineers are an arrogant bunch.
If you've spent most of your life with a few thousand dollars worth of musicians in the studio, making a decision every second and a half... and you and  they are going to have to live with it for the rest of your lives, you'll get pretty arrogant too.  It takes a certain amount of balls to do that... something around three"
Malcolm Chisholm
Klaus Heyne
Re: Neumann M269c.
« Reply #2 on: April 21, 2004, 11:09:46 pm »
Sorry Fletcher, no Cohiba this time.
The connector in the M269 is very common, still being manufactured by Binder in Italy and identical with all other 200-series Neumann broadcast connectors EXCEPT the U67 connector, whose pin pattern was offset by 10 degrees (on purpose, so that you don't wack 210 volts into your AC701-equipped mics)
Regarding the "loose" connection: I may not understand which part of the set up is loose in your system, so let's be really specific:
1. The male connector in the bottom of the mic is loose on purpose, to allow it to adjust its position with slightly off-set cable females which, because they are rigidly embedded in the connector housing, could otherwise bend the fragile connector shoes. So that part is OK, and will not cause any intermittent mic operation. I also must say that I have very rarely encountered bad plating on Tuchel connectors which would cause bad contact.
2. You need to look really carefully inside of the cable female  and inspect:
a. the integrity of the black plastic insert (broken off portions? Missing friction washer? Can the connector insert be twisted inside the metal housing?)
b. missing, broken or intermittent solder connections between cable conductors and connector pins
In either case, at worst you are looking at  some sweat equity and/or a new connector insert (maybe $50.-) to get you back on the road.
To whom should you send this mic? First, analyze and trouble shoot, then make the decision, how sophisticated of a mechanic you will need. This is not rocket science; a technician with a good soldering resume is going to be fine.
Kind regards,
Klaus Heyne
German Masterworks
www.GermanMasterworks.com
Fruition Music
Re: Neumann M269c.
« Reply #3 on: April 22, 2004, 12:00:18 am »
Kevin,
I found a similar issue with my M269c after wiring up the N52 (Klaus thanks for the pinout you emailed me back then), I started with the original gray Neumann cable and connector but ended up replacing it with new Gotham Audio cable. Not only did I find the female connector corroded, it somehow wasn't even assembled correctly which made it difficult to spin and screw in.
Took some time and care, cleaned the connector and all the partsc, adjusted the 4v in the N52 to the AC701 and its been wonderful ever since. I will add that you may not want to operate the 269c or any mic with the AC701 if something is intermittent,...stray voltages spikes to 701's can possibly damage them I've been told.
Klaus its great to have you here in this forum, thank you for sharing your valuable time and knowledge.
Dean Dydek
www.deandydek at yahoo.com
Fibes
Re: Neumann M269c.
« Reply #4 on: April 22, 2004, 09:46:07 am »
It seems to be the insert or something related. Something I should have added in my original post is that i'd like someone to give it and the power supply a once over before I put it back into action. The mic is that important to me.
I would love to hear what y'all think makes this mic so magical, i think i know but to be honest, I'm no scientist.
Fibes
The Studio
malice
Re: Neumann M269c.
« Reply #5 on: April 22, 2004, 11:23:41 am »
Hi Klaus,
Great idea to start this forum !
I gotta chime in this discussion.
I agree with fibe here, this mike has a magic on his own. I think it's probably my favorite female vocal microphone of all time.
I noticed that it is not like a 67 with a slightly different freq response.
It react dynamicaly in a noticable different way (Am I close Fibes ?) ...
I'm trying to buy another one btw.
I would love to hear Klaus opinion
best
malice
Klaus Heyne
Re: Neumann M269c.
« Reply #6 on: April 22, 2004, 12:52:43 pm »
Denis/malice
I have heard other people as well making a distinction in the sound of two mics that are , at least in theory, very closely related: The M269 and the U67.
First off, here are the only technical differences between a U67 and an M269 (non 'c' version) mic, contrary to what you might have heard regarding different frequency response components or circuitry:
-The tubes (EF86 vs. AC701)
-The voltage and current going to the tubes (beyond the scope of this forum.)
-The electronic components (resistors) which accomplish
 that.(same as above.)
Over the years I have repeatedly made the following comparison test, in order to find out what factor that tube difference has on the sound of the mic:
I used two stock, well working units, both with Neumann selected Telefunken tubes, and both working at optimal operating conditions. I then transplanted one of the capsules back and forth, between M269 and U67 amp, so that the considerable influence of each capsule's individual sound was eliminated from the tests by using just one capsule for both mics.
What I found was an ever so slight softening of the dynamics with the M269. No large, fantastic revelations beyond that.
However, if you use the M269c's amp on that test, you will find the same, more noticeable characteristics shared with all cathode biased tube mics- a slendering of the mic's midrange, and a slightly increased transparency in the midrange, at the price of the robustness of the mids.
That's it.
All of these audible differences, by the way, are on a much smaller scale than the differences encountered when comparing two different K67 capsules. I suspect that Denis's wonderful mic's secret is the very capsule he has in that mic, over and above any other distinctions of model or series.
Kind regards,
Klaus Heyne
German Masterworks
malice
Re: Neumann M269c.
« Reply #7 on: April 22, 2004, 01:21:09 pm »
Klaus Heyne wrote on Thu, 22 April 2004 18:52
Klaus,
thank you for the reply
I might have been very lucky with the one I purchased.
I agree that I've heard some great U67 and some terrible ones ...
So as you say, maybe the difference is not that obvious.
I just noticed that you prefer unanimous posts
So I will comply gladly to the specific requirement of this great new forum
best to you
Denis Moulin aka Malice
Montpellier
France
Klaus Heyne
Re: Neumann M269c.
« Reply #8 on: April 22, 2004, 01:39:49 pm »
[quote title=malice wrote on Thu, 22 April 2004 10:21]
best to you
Montpellier
France
That's the spirit!
Now we can talk among friends.Thank you and:
Welcome to the inner circle!
Klaus Heyne
German Masterworks
Fruition Music
Re: Neumann M269c.
« Reply #9 on: April 22, 2004, 10:27:52 pm »
Ocassionally I see the SM69 stereo tube for sale, its supposed to be the stereo M269c. Klaus, have you or others out there made the comparison in similarities between both mics sonically?
Also does the grill/scrren being different shapes change the sound much? In the late 80's I remember the Stephen Paul Mix mag article tests with the U47, its sonic differences with and without the grill on/off...anyone care to share their findings?
Dean Dydek
Mark Lemaire
Re: Neumann M269c.
« Reply #10 on: April 22, 2004, 10:42:24 pm »
At one point I tried like mad to buy an SM69 because of one that I loved I used all the time at a certain studio. During this period, I got another SM69 sent to me on approval. Upon firing it up I got the immediate impression that it had 'that SM69 tone" that I loved. A certain sort of 'edge' in the upper mids. Alas, I did not buy that one because the head's pivot mechanism was mechanically screwed up.
I eventually wound up getting a pair of M269s instead (probably a much more versatile solution).  Nevertheless, I did NOT get 'that SM69 tone that I loved" upon firing them up. I got a different sound that I love very much instead. A little less edgy, a little more 'balanced', for want of some better term.
Later, Klaus modded/ optimized the pair. Lovely! Their typical use for me these days is (set to omni) as one of two main pairs for orchestra. The other pair is (2) DPA4003. The Neumanns 'win' perhaps 70% of the time.
Mark Lemaire
Mark Lemaire
http://www.myspace.com/MarkLemaire
http://www.rubatorecording.com/
Audiophile recording of your music. Anywhere. Anytime.
Klaus Heyne
Re: Neumann M269c.
« Reply #11 on: April 23, 2004, 12:30:38 am »
There are some relevant differences in the design of the M269 and the tube SM69: Never underestimate the power of the transformer on the sound! (Have you ever heard a U47 with a Triad trafo? Awful!)
The transformer in the U67/269 is a very beefy affair with lots of iron, fat and complex winding patterns (I'm sure Oliver could add a thought or two here) whereas the SM69's has to be slim enough to fit the narrow housing tube.
That scratchy upper-mid behavior of the SM69 Mark is mentioning is mainly due to the circular head basket with its funny resonances, also it's due to the wide open high end the SM69 amp is run-  remember, the mic was commissioned and designed for distance orchestra pickup, and, to compensate for the air molecule friction over distance (high fre. attenuation) the mic amp's high end was barely attenuated, so that the capsule's natural boost of 6-8dB @10k was left almost undisturbed.
Kind regards,
Klaus Heyne
German Masterworks
Oliver Archut
Re: Neumann M269c.
« Reply #12 on: April 25, 2004, 09:46:41 pm »
There are some major differences in those two transformers, the BV12 used in a U67 and M269 is a 49% Nickel core that has 10 times more core cross section than the tiny U17 type used in the SM69. To compensate for the small size they use a different nickel alloy that is more dense. In fact if you use the same type of Nickel for the BV12 and stick it in a M269 the base sound will change dramatically.
Aside the different alloy the BV12 is a multi section mantel UI core, with a feedback winding for the low cut, etc. where the mini UI in the SM69 is nothing more than a simple mantle x-former, that means just secondary over primary winding, this alone gives the SM69 design a head start.
Best regards,
Oliver
Oliver Archut
www.tab-funkenwerk.com
We are so advanced, that we can develop technology that can determine how much damage the earth has taken from the development of that technology.
Klaus Heyne
Re: Neumann M269c.
« Reply #13 on: April 25, 2004, 10:06:31 pm »
Oliver Archut wrote on Sun, 25 April 2004 18:46
Aside the different alloy the ( M269/U67 transformer) is a multi section mantel UI core, with a feedback winding for the low cut, etc. where the mini UI in the SM69 is nothing more than a simple mantle x-former, that means just secondary over primary winding, this alone gives the SM69 design a head start. Oliver
Oliver,
Please explain (in VERY SIMPLE terms!) why the transformer construction in the SM69 gives this mic a 'head start' as you call it, when you seemed to praise the beefy construction and winding complexity of the transformer of the U67 early in your post.
Kind regards,
Klaus Heyne
German Masterworks
Oliver Archut
Re: Neumann M269c.
« Reply #14 on: April 25, 2004, 11:32:40 pm »
Head room is not everything, the winding technique is about 50% of the sound. The SM69 windings would make a better x-former on the BV12 core....
The feedback winding of the multi layered BV12 sits in-between primary and secondary shielding and creating a degree of phase shift....
Best regards,
Oliver
Oliver Archut
