Author Topic: Akg 414 EB / ck12  (Read 8290 times)
Julien Asencio
  • Real Full Name: Kidbill
Akg 414 EB / ck12
« on: August 24, 2011, 02:33:59 am »
Hi, I would like to know how to store properly a Akg 414 eb with ck12 to avoid tension loss and keep it well. Does the foam in the head basket should be cleaned from time to time?
As well what are the mods do you make to this model mr Heyne? I'm happy with the sound but I'm curious. Thanks.
klaus
Re: Akg 414 EB / ck12
« Reply #1 on: August 24, 2011, 03:41:33 am »
Julien,
The eventual failure of the adhesive in many CK12 over time which relaxes the pre-tensioned diaphragms is not very well understood. Neither is the primary cause for tension loss- molecular or substrate changes in the diaphragm material.
There is little you can do to prevent loss of diaphragm tension in a CK12 beyond housing, storing and treating it the way you would your own child or pet: no temperature extremes, no transportation in a car trunk in the heat of summer, and no prolonged high sound pressure level exposure.
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
Julien Asencio
« Reply #2 on: August 24, 2011, 11:17:59 am »
Thanks Klaus, and what about your mod? what do you improve in it?
Do you make any change in the circuit?
klaus
« Reply #3 on: August 24, 2011, 04:57:10 pm »
Julien,
I don't allow business promotion, including my own, on this forum.
Please contact me privately.
Thanks,
Klaus Heyne
German Masterworks®
Julien Asencio
« Reply #4 on: September 03, 2011, 04:57:47 pm »
As I don't have box, would you know if there's some box available to store the 414 correctly?
Thanks
Julien Asencio
« Reply #5 on: September 16, 2011, 11:44:26 am »
bump..?
klaus
« Reply #6 on: September 16, 2011, 02:46:43 pm »
Current models of C414 are pretty much identical in shape with your C414EB, so a factory AKG 414 case of current production will be totally adequate, never mind the writing on the case.
Klaus Heyne
German Masterworks®
halocline
  • Real Full Name: Matt Dunne
« Reply #7 on: October 11, 2011, 09:21:27 am »
Regarding the box, I recently bought the aluminum AKG briefcase box for a pair of 414s. The price was reasonable considering what I had expected. (maybe $60?) However, when I got the box, the was no foam cut out for the 2 mics and shockmounts; just the empty box. I don't know where you would get the pre-cut foam, maybe it wouldn't be too hard to cut some yourself.
BobSchwenkler
« Reply #8 on: October 15, 2011, 01:26:00 am »
When I made a box for my KM86s I went to the foam store (yes, we have a foam store here) and got some ~1/2" closed cell. I was able to make gradated cutouts in the different layers such that the mics nestle in there quite nicely. I also made cutouts for a stereo bar and the mic clips. Didn't take too long, just use a very sharp utility knife or similar.
klaus
« Reply #9 on: October 15, 2011, 01:49:56 am »
Sexy close-up picture, please!
Klaus Heyne
German Masterworks®
BobSchwenkler
« Reply #10 on: October 15, 2011, 02:25:36 am »
Sexy ones, ha! I like that you specify sexy ones. This is the best my point and shoot plus poor lighting combo is gonna give without some Photoshopping, it'd take more time "airbrushing" than I'd like to spend to get these photos looking really sexy.
I built the case out of some shipping crate plywood (you can see the broken glass and umbrella with rain falling on it warnings), some stain and varnish. The grey foam is a slightly different thickness than the yellow, these were what was stocked that got me a good fit for the mics.
No superb craftspersonship here, but it's got character, looks nice, and works well. Could have made it a bit smaller, I think I had some idea of fitting something else in there when I was building it...
I tried to attach these photos but the forum software wouldn't let me.
klaus
« Reply #11 on: October 15, 2011, 02:29:42 am »
The umbrella top: brilliant!
Now if you could just add a nice little plastic bag as dust, foam and moisture barrier around each mic, you're done!
Klaus Heyne
German Masterworks®
halocline
« Reply #12 on: October 15, 2011, 09:05:34 am »
That looks great. I've heard that using an electric carving knife is a good way to cut foam.
BobSchwenkler
« Reply #13 on: October 15, 2011, 12:39:46 pm »
I do have that, I took them off for the sexy photos!
BobSchwenkler
« Reply #14 on: October 15, 2011, 12:43:01 pm »
That would probably work quite well for the longer, straight cuts.
