Pages: 1 ... 35 36 [37] 38 39 40   Go Down
Author Topic: Sontecs...  (Read 268911 times)
24-96 Mastering
Re: Sontecs...
« Reply #540 on: October 19, 2010, 12:51:27 AM »
Hey everyone, there's a few things I'm wondering about. Can anyone help?
- has anyone modded (or considered to mod) their Sontec 4x2 to have a "hardwire" (relais or switched) bypass? If so, can you give details?
- what dimensions are the 4x2 models? (depth and height)
- Phil (and whoever else has colored knob caps): where / how did you obtain / order them?
24-96 Mastering
CD - SACD - DVD
Phil Demetro
Re: Sontecs...
« Reply #541 on: October 19, 2010, 11:07:25 AM »
24-96 Mastering wrote on Tue, 19 October 2010 00:51
I got the knob covers through Elma many years ago. The salesman told me that that was the last of their stock. I'm sure they would have found another source by now?
It's worth it because I don't get the bands mixed up now.
For all the money I spent/wasted on mods I would say with certainty to don't bother with a bypass/relay/etc for the Sontec. It'll get used on everything you master so there's no point in bypassing it. I can't hear it when it's in anyway. Can you bypass it at your console?
I moved the PSU out of mine. New chips, new caps. I've got a good one.
____________________________________________________
Phil Demetro
Mastering at The Lacquer Channel, Toronto
http://www.lacquerchannel.com/phil-demetro/
bblackwood
Re: Sontecs...
« Reply #542 on: October 19, 2010, 11:28:00 AM »
It appears Elma still makes the collet knob caps in six different colors: http://www.elma.com/Admin/ProductionFiles1//ProductTypeFile/ 137/English/MechanicalComponents.pdf
Brad Blackwood
euphonic masters
24-96 Mastering
Re: Sontecs...
« Reply #543 on: October 19, 2010, 01:09:21 PM »
bblackwood wrote on Tue, 19 October 2010 17:28
Thanks! I came across this but assumed they're available in large quantities only.
Phil Demetro wrote on Tue, 19 October 2010 17:07
Was it a specific person or did you just phone them? On Elma's web site they state that switches & covers need to be ordered in quantities of 100... just asking in case it matters who you contact.
I run a straigh chain, no console. But thanks for the advice, I think I'll indeed try it out first as it comes.
Can I ask why you moved the CPU? Heat?
24-96 Mastering
CD - SACD - DVD
24-96 Mastering
Re: Sontecs...
« Reply #544 on: October 19, 2010, 01:13:46 PM »
Oh, I forgot to proudly announce:
I'm buying a Sontec 462-C9 Very Happy
24-96 Mastering
CD - SACD - DVD
bblackwood
Re: Sontecs...
« Reply #545 on: October 19, 2010, 01:23:26 PM »
24-96 Mastering wrote on Tue, 19 October 2010 12:13
Very good, you'll love it.
As for Elma - call them directly, they sell in small quantities to individuals. It's how I've gotten all my Elmas...
Brad Blackwood
euphonic masters
Laarsø
Re: Sontecs...
« Reply #546 on: October 19, 2010, 02:20:34 PM »
Wook wrote on Tue, 17 August 2010 19:49
The Mastering Lab EQ has always been using solid state amp designed by Sherwood Sax from its start. We are using own transformer-less tube electronics but not on the EQ. And our EQ has nothing to do with Sontecs.
Sunny
The Mastering Lab.
Thanks for clarifying this, Sunny.  I was not making this up from scratch, however.  Our friend in this matter is under strong impression that while TML eq's development was not in cohoots with Massenberg or ITI, the Sontec HS-1000 amp was indeed auditioned and to some extent tuned by Massenberg (and Sax (D.?)) at TML.  It is all the more noteworthy that all three designers' eq's, who were shooting for cost-no-object performance, were each, early on, choosing the trafo-less and solid state tops, as you have indicated,  and with different sounding results, even though, the point about the voicing of the HS-1000 op amp being done at TML was that it was made to sound good there, and the room (amps and limiters?) was already tube/trafoless - even if the Sax eq was only partially that.
How early on were third party "store-bought" processors added to the rack?  Are any of these run stock?  (e.g., EAR)
Best regards,
    Laars
Space Camp Mastering
laarsoglethorpe@gmail.com
"Lack of DSD post filtering fried a lot of expansive twitters." (D. L.)
jdg
Re: Sontecs...
« Reply #547 on: October 19, 2010, 04:59:33 PM »
24-96 Mastering wrote on Tue, 19 October 2010 10:13
new or used?
john mcCaig
-Mothery Earworks Clarifold Audipure
Ben F
Re: Sontecs...
« Reply #548 on: October 19, 2010, 06:56:09 PM »
The bypass is quite transparent, certainly no cause for modification.
Congrats on purchasing the best mastering EQ ever made!
TotalSonic
Re: Sontecs...
« Reply #549 on: October 19, 2010, 07:31:52 PM »
Ben F wrote on Tue, 19 October 2010 18:56
fwiw - I'm not sure what is stock on the 4xx series - but the bypass that came stock on my MEP-250EX was a "soft" one and certainly not "transparent" by any means.  I had mine modded by Dan Zellman to replace the 2 per channel soft bypasses buttons with a single button true "hard" bypass - but now that I have the Manley Backbone I never use this as I can bypass it from the insert controller instead.
Best regards,
Steve Berson
Adrian Morgan
Re: Sontecs...
« Reply #550 on: October 19, 2010, 08:29:18 PM »
No hard bypass on the new 432's either, although to me the 432 bypass does sound a lot more transparent than the 250EX.  The 432 here is on it's own insert on the Dangerous Master to alleviate the problem.
I would recommend trying a 432 before a buying 462 if you can.  The ability to dial a different setting for L vs R or M vs S is one of the most powerful uses of the Sontec sound in my opinion.  With the right support EQ you won't feel like extra bands are needed.
Adrian Morgan
Timeless Mastering
http://timelessmastering.com
24-96 Mastering
Re: Sontecs...
« Reply #551 on: October 19, 2010, 09:20:09 PM »
bblackwood wrote on Tue, 19 October 2010 19:23
I've gotten in contact with them, thanks so much for your help (in the PMs too)!
jdg wrote on Tue, 19 October 2010 22:59
new or used?
(Slightly) used. I'm told the unit is in great condition.
Adrian Morgan wrote on Wed, 20 October 2010 02:29
That's encouraging. My 250C has a relay bypass mod, so I don't know what its original bypass sounds like, but when patched in with all pots at 0, the unit certainly isn't completely transparent.
I don't have the option to try a 432 first, but I'm actually liking the idea of having a 462, not because of the number of bands, but because of ganged controls. The ability to operate the EQ without having to match sides should make for fast, intuitive fiddling. With my eyes closed and the other hand on the compressor, if I want Smile
Lack of separate L/R & M/S settings (in one of 4 EQs) is a price I'm willing to pay for that.
24-96 Mastering
CD - SACD - DVD
24-96 Mastering
Re: Sontecs...
« Reply #552 on: October 19, 2010, 09:35:45 PM »
PS: now I have to figure out if and how I want to colorize my Sontec. There are 8 bands and 6 knob colors (red, yellow, green, grey, black, blue). Does anyone have any ideas?
24-96 Mastering
CD - SACD - DVD
Jerry Tubb
Re: Sontecs...
« Reply #553 on: October 19, 2010, 11:00:35 PM »
24-96 Mastering wrote on Tue, 19 October 2010 20:35
perhaps follow GM's color scheme?
index.php/fa/15670/0/
JT
Terra Nova Mastering
24-96 Mastering
Re: Sontecs...
« Reply #554 on: October 20, 2010, 02:39:16 AM »
Jerry Tubb wrote on Wed, 20 October 2010 05:00
Heresy!
Fun aside, thanks for the suggestion, I'll sketch it up to see what it'd look like. Actually, Burgess recently told me he has been asked to dress up a 250 as a GML before.
Come to think of it, it's a bit vain to ask you and the forum for gear decoration ideas... I'll experiment a bit and will post some pics once the unit is done Smile
24-96 Mastering
CD - SACD - DVD
Pages: 1 ... 35 36 [37] 38 39 40   Go Up
Page created in 0.052 seconds with 19 queries.
