February 27, 2021, 01:55:06 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
R/E/P
Recording - Engineering & Production
(Moderators:
Fletcher
saint
Compression chains
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Compression chains (Read 2987 times)
Joram
Newbie
Offline
Real Full Name: Joram Pinxteren
Compression chains
on:
June 12, 2011, 05:56:43 pm »
Recording chains (mic/di>preamp>eq>comp or mic/di>preamp>comp>eq) influence the performance of musicians when recording. Mixing chains alter the sound further. To what extend do you use compression chains? Do you have any specific ideas how to set up a chain or standard combinations?
(Michael B., you're not supposed to explain MBC once again ;-)
Joram
www.jorampinxteren.com
www.legacystudio.com
musiclab
Newbie
Offline
Real Full Name: Lou Gimenez
Re: Compression chains
Reply #1 on:
June 19, 2011, 11:46:55 am »
I rarely chain compressors together, usually it happens when someone recorded a track at home and they tracked it with out any. If I tracked the project usually that's not necessary.
2" 24 track and a whole lot more
www.musiclabnyc.com
Fletcher
Administrator
Hero Member
Offline
Reply #2 on:
June 23, 2011, 01:11:47 pm »
I've done it on a fairly regular basis... a lot depends on how fast I have to work. 3 compressors each doing a db - db & a half of gain reduction will sound far less intrusive than 1 unit doing 5 or 6db of gain reduction... so if you have the time to set them up properly its often not a bad thing to string a few together.
I hope this is of some assistance.
Peace
CN Fletcher
Recording engineers are an arrogant bunch
If you've spent most of your life with a few thousand dollars worth of musicians in the studio, making a decision every second and a half... and you
and
they are going to have to live with it for the rest of your lives, you'll get pretty arrogant too. It takes a certain amount of balls to do that... something around three"
Malcolm Chisholm
rosshogarth
Newbie
Offline
Reply #3 on:
June 24, 2011, 11:38:49 am »
ch ch ch chains
chain of fools
not
I always chain or I chain a lot I must say
a tube comp into a fet comp
a fat grabby comp pulling down peaks into a slower mushy comp for tone
Whatever works guys
The practice of forgiveness is our most important contribution to the healing of the world.
The standard of success in life isn't the things. It isn't the money or the stuff. It is absolutely the amount of joy that you feel.
Joram
Newbie
Offline
Reply #4 on:
July 07, 2011, 06:25:08 am »
Thanks so far, guys!
Joram
Ward
Newbie
Offline
Real Full Name: Neal Ward
Reply #5 on:
July 14, 2011, 09:55:20 am »
I will often use a compressor capable of focused or narrow band compression (like an LA-22) to take down the hottest transients a couple db at certain frequencies with realatively quick attack + release. Then patch that into an La-2a or La-3a for that nice slow Urei thing. This provides a nice smooth effect where the LA-22 smoothes any bumps before hitting the Urei. If I want to then go farther (ie. that super-compressed vocal sound) I add a DBX 165 or 160 vu after the Urei set to fast attack/release. Anything that slips through the slower response time of the Urei is caught by the DBX which then lets go of it as the Urei grabs hold. By carefully selecting thresholds you can get a nice smooth, even compression all the way up to an absolutely crushed signal with no pumping of breathing. Basically letting each component in the "chain" work to its strengths and not asking one unit to do everything.
Print
Pages: [
1
Go Up
« previous
next »
R/E/P
(Moderators:
Fletcher
saint
Compression chains
